Strange electrical thing in inner wing.
Frax
bolted to the rear vertical part of the inner wing outboard of the brake servo, it's the resistor unit for the headlight dim dip system.
it looks like this bit in the scan below
the heater blower motor resistor is inside the heater case under where the wiring goes in.
I seem to remember that these were being sold on ebay to replace burnt out heater fan motor resistors. It looks similar to one I had on my 90. Often the second fan speed setting resistor burns out, and this is a replacement/upgrade.
EDIT, and having just seen ralph's post he could also be right.... if the wires appear to be connected to the lights then its Dim/Dip, if they go back to the dash area then its the heater motor. Same resistor is used for both aftermarket applications.
