Tanuki Posted October 8, 2011 Share Posted October 8, 2011 Gas-pressure Bilsteins are wonderful. But they are a real pain to fit on the front because the gas-pressure extends them fully and this makes it a mega-struggle to refit the suspension-trumpets. My 'quick fix' is to fully-compress the shock-absorber then get someone to put several turns of duct-tape around the lower part to keep the outer 'barrel' part taped to the inner cylinder. You can now refit the shock-absorber into the centre of the spring, bolt the trumpet back in place and put the nut loosely on the bottom thread of the shock-absorber. Then cut round the tape (through the spring) with a craft-knife. The gas-pressure will extend the shock-absorber and you can then wiggle it about so that the upper threaded piece emerges through the hole in the trumpet. Trust me: doing it this way means you can save on curses and avoid finger-trapping 'unintended extension'. --Tanuki. "Today's forecast is: moderate to heavy patches of Frogs and a sunny outlook, but with a belt of sentient wellington-boots moving in from the west as the weekend comes to an end, followed by a visit to the psychiatrist for better drugs sometime early Tuesday" Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 8, 2011 Share Posted October 8, 2011 My OMEs were the same... so I just used about 3 or 4 zip ties... compress it up and ziptie the two ends . Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2011 Share Posted October 8, 2011 my OME's came with a metal rod hooked at each end to keep the partly closed up. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 8, 2011 Share Posted October 8, 2011 Mine did too, but as I was fitting on the front they would have been a right PITFA to get off again. the rear ones would be OK though . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 9, 2011 Share Posted October 9, 2011 I used a luggage ratchet strap on mine. Quote Link to comment Share on other sites More sharing options...
