bishbosh Posted October 18, 2011 Share Posted October 18, 2011 I need to find a short length of ceramic tube - say 50mm long. OD and ID can be quite wide ranging - OD no more than about 12mm and ID no less than 2mm. It is to act as a heat shield for my bbq ignition wotsit - the insulation has been burnt off and it now arcs to the bbq case rather than in the combustion chamber and doesn't light the gas . Eblag only has short lengths which are not going to work. Anyone got any other sources that don't require me to order several hundred units? Cheers, Bish. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 18, 2011 Share Posted October 18, 2011 I will have a rummage at work! Quote Link to comment Share on other sites More sharing options...
simonr Posted October 18, 2011 Share Posted October 18, 2011 You could make your own out of modelling clay? even in an un-fired state, so long as you let it dry thoroughly its a pretty good dielectric. Si Quote Link to comment Share on other sites More sharing options...
sean f Posted October 19, 2011 Share Posted October 19, 2011 If you could increase the size for the OD it might be worth a look at the shrouds for either a plasma cutter or tig welder. Some aren't to expensive and you maybe able to aquire one a bit to knackered to use but good enough for your purposes. Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted October 20, 2011 Share Posted October 20, 2011 I have a piece of ceramic tube that you can have, but it might be a bit delicate for your needs. - ID 3mm, OD 6mm, length 260mm. I'll be travelling down the M5 past Western on Monday mid-day ish, or can drop it off at 'Turbocharger's house, if you ever get up that way. Quote Link to comment Share on other sites More sharing options...
Superpants Posted October 20, 2011 Share Posted October 20, 2011 What about a tube from a spark plug- crude but might work? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 20, 2011 Author Share Posted October 20, 2011 I have a piece of ceramic tube that you can have, but it might be a bit delicate for your needs. - ID 3mm, OD 6mm, length 260mm. I'll be travelling down the M5 past Western on Monday mid-day ish, or can drop it off at 'Turbocharger's house, if you ever get up that way. That sounds pretty much perfect! don't need all of it though! If you can leave it with John I'll sort out collection. Very generous of you - thanks!! Quote Link to comment Share on other sites More sharing options...
