burning oil.. as they all do.
discomikey
so a few questions as i think im about to do a semi overhaul on the temporary landy engine.
2.25diesel. i think its a 3brg any way to tell from the outside?
im guessing its gonna need new piston rings?
while im there im gona need all gaskets, exhaust/inlet, head, sump, rocker cover
might aswell do the bearing shells.
im going to be perfectly capable of this work, just wandering can i do it in situ? i think i should be able to. also will i need oversized 0.10 rings or as im not boring it out will standard be ok? i also understand that it will need them running in, how long for? i have got a proper land rover workshop manual for this and all the info is probably in there too. but i cant get to it at the mo.
any help appriciated.
If its temporary does it really need doing? personally and having rebuilt one of these many years ago i wouldnt order anything until you have had the head off and dropped the sump and had a good look first as you may find the bores are more worn than you first thought, how much oil is it burning? is it giving off dense blue smoke or just the odd puff? tried a thicker oil? you can do all the work in situe assuming your not reboring but if you want to remove the crank then either engine out or pull the gearbox back, probably easier to remove the engine, i left mine in situe and covered the crank during honing
3brg's dont have strengthening ribs cast into the block, around the bottom edge (where the sump attaches)
5brg's do have strengthening ribs cast into the block around the bottom edge.
if you are not having it re bored, the current pistons with new rings will be fine if they are OK condition. obviously its a different story if you are having it re bored.
  • 2 weeks later...
,I have just re ringed my 2.25d and have changed the shells and gaskets all parts including delivery cost. £65 from paddocks spares
It can be done with engine situ and it took me about 9hrs start to finish, best bi of advice is while the pistons are out use a honing tool and remove the glaze out of each piston chamber/barrel, use plenty of oil when fitting the shells
Take your time and don't rush
  • 1 month later...
check your injection timing is absolutely cock on before even stripping.
dunno why you have to check injection timing is perfect before doing this as the injection pump doesn't need to be removed the only thing that needs to be done is injectors and injector pipes need removing from it.
the crank shaft doesn't need to be removed and the vlaves are done by push rod so timing isn't an issue
the hardest thing i found doing this job was removing the injectors as i mine had proberbly never been removed before and were stuck fast
The thing you need for this is a slide hammer.
I spent about 2 hours struggling to get a single injector out of my Volvo. Went and got one of these. The other three came out in under 30 seconds (total).
If it's burning "oil" I have found with nearly every 2.25 that wear in the injection drive spindle retards the injection timing and creates blue smoke with minimal wear it can make a good engine look knackered.
So obviously you will check the easiest things first, like valves seals before completely rebuilding an engine.............
You can always loosen the bolts (only by a turn) that clamp the injectors and throw the engine over on the handle to loosen stuck injectors.
Correct me if I'm wrong but when I placed the original answer you have not mentioned any oil loss in your OP?
of course with the information then my answer is somewhat void, but it would really help if you explained the symptoms or reasoning for tearing your motor down, fully in the first place.
