need4speed Posted November 29, 2011 Share Posted November 29, 2011 Needing front nearside door internals for the new steel-type door I have fitted. Apart from the window, I don't have any of the internals at all. Was looking through my old 110 parts catalogue and wondered if things like window regulator, window channels etc etc were the same? I'd be interested to know if anyone had swapped old internals into later type door. Quote Link to comment Share on other sites More sharing options...
Frax Posted November 29, 2011 Share Posted November 29, 2011 As far as I know they are the same, I hope to be re skinning my ally doors with a new steel skin this week, it will use the old steel frame so everything else should just swap over. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 29, 2011 Share Posted November 29, 2011 I believe the internal support plate is different, so most things probably won't be a straight swap. Should be doable though with a few pieces of steel here and there to make up brakets or extend them etc. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted November 29, 2011 Share Posted November 29, 2011 i did mine last year and they are almost identical everything fits well but you will need to make a small s shaped bracket to hold the bottom of the window regulater and trim a small peace of the door card on the lock side Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted November 30, 2011 Share Posted November 30, 2011 as luck would have it, there's some 2009 door internals on ebay Quote Link to comment Share on other sites More sharing options...
