Discoverynath Posted January 27, 2012 Share Posted January 27, 2012 Iv got a disco 1 and the battery is dead. Fob now won't work and tried the key in both front doors and boot and they don't even turn. Maybe different barrels I don't know. Any advise how to get in or which barrel is the best to hammer a screw driver in? Help appreciated Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 27, 2012 Share Posted January 27, 2012 Have you ever had a key that worked in the door, or just locked/unlocked by fob? It is normal that the ignition key will work the doors, but if it has had a new barrel they won't match, and not allow you to unlock the vehicle. Do you have a spare set of keys.... with a mystery key that doesn't appear to do anything...? Quote Link to comment Share on other sites More sharing options...
Discoverynath Posted January 27, 2012 Author Share Posted January 27, 2012 Only had it 6 months. Gonna wd40 the barrels and leave them overnight. Quote Link to comment Share on other sites More sharing options...
Pwyll Posted January 27, 2012 Share Posted January 27, 2012 Try some releasing oil in through the keyhole, could be just gunked up from lack of use. Failing that, join the AA making sure to get homestart, wait a day then give them a call. A Disco should take them about thirty seconds to get into for you. ;-) Quote Link to comment Share on other sites More sharing options...
sierrafery Posted January 27, 2012 Share Posted January 27, 2012 if u have a 7 pin towing socket with live in pin3(not all are so) insert something in pin 3 as to be able to put a charger on there...if not jack up the front and try to reach the live wire on the alternator then connect the charger there... in about 1 hour u must have enough juice to make the central locking work, unless i's a jump starter type and u'll get in right away. Quote Link to comment Share on other sites More sharing options...
Boris113 Posted January 27, 2012 Share Posted January 27, 2012 I presume the reason that the fob has stopped working is due to the dead vehicle battery and not any other reason? If so then I've had the same problem. There is a way to open the bonnet from outside the vehicle, once open, charge up the battery and the fob should be able to open the central locking once again. Harry Quote Link to comment Share on other sites More sharing options...
Discoverynath Posted January 27, 2012 Author Share Posted January 27, 2012 Borris/Harry how can I open the bonnet. That's the bit I'm struggling with. Nathan Quote Link to comment Share on other sites More sharing options...
davyd8899 Posted January 27, 2012 Share Posted January 27, 2012 coat hanger down between the window and door, put a small hook shape on the endwriggle it around the door lock and when its hooked pull.......... it works took me 20 seconds to get in mine Quote Link to comment Share on other sites More sharing options...
Discoverynath Posted January 28, 2012 Author Share Posted January 28, 2012 All sorted. Pull n.s headlight out and cut away bonet cable cover and pulled inner cable. Job done:) Quote Link to comment Share on other sites More sharing options...
Boris113 Posted January 29, 2012 Share Posted January 29, 2012 Sorry just seen your Q. On my 300tdi i took a very strong bit of wire and bent the end into a hook. Feed through the top slat in the grill and pull the cable towards you, once it's close enough you can reach it with your fingers. If you pull the outer cover hard enough then it will pop it open. Quote Link to comment Share on other sites More sharing options...
