Frax Posted February 4, 2012 Author Share Posted February 4, 2012 Yip started and run - strange I know. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 4, 2012 Share Posted February 4, 2012 If you were to try straightening them as a temporary measure I'd worry about them fracturing at the sharp bend..... Quote Link to comment Share on other sites More sharing options...
Frax Posted February 4, 2012 Author Share Posted February 4, 2012 You are right,will just have to order some and wait I suppose, Do I need to set all the valves again when I fit new ones. Quote Link to comment Share on other sites More sharing options...
western Posted February 4, 2012 Share Posted February 4, 2012 You are right,will just have to order some and wait I suppose, Do I need to set all the valves again when I fit new ones. Yes you will have to reset the valve clearances. Quote Link to comment Share on other sites More sharing options...
Frax Posted February 4, 2012 Author Share Posted February 4, 2012 Thought I would - I hate waiting on parts. Just started to snow up here as well and here me with no Land Rover. Quote Link to comment Share on other sites More sharing options...
raymond90 Posted February 4, 2012 Share Posted February 4, 2012 If your in a hurry to get the parts theres a place called RDH landrovers up in the tomintoul area. You could give him a try ive been to him a few times and he usually has most parts in stock and if not he might have an engine sitting he could take them out of to get you going. 01807590718 is his number. Raymond Quote Link to comment Share on other sites More sharing options...
Frax Posted February 4, 2012 Author Share Posted February 4, 2012 Thanks Raymond will keep him in mind for future disasters. Phoned main dealer in Aberdeen Town & County and they had none so phoned Frank Ogg in Elgin and he had six. Went to Elgin and picked 4 up - home and fitted - set the valves started her up and she ran as sweet as a nut apart from a strange metallic squeak. Still to find where it is coming from. Decided to take it for a run and all was well till I got back home and back into the garage. Noticed an oil drip - had a look underneath and it looks like the whole lot will have to come apart again, crank shaft seal has gone. Its not bad but a steady drip of about 1 per min. Looks like my old belt has ruined the seal as it was new about 2 months ago. Will it still be OK to drive till I order a seal as I am not going running round again - Dont want the oil spraying all over my new cam belt and wrecking it. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 4, 2012 Share Posted February 4, 2012 If oil gets on the cam belt it'll severely weaken it (the oil makes the belt feel like soft rubber), which may well break in the near future. If the oil is not on the belt, then you can get away with it for a while. Problem is - you just don't know if it's missing the belt. Les. Quote Link to comment Share on other sites More sharing options...
Frax Posted February 4, 2012 Author Share Posted February 4, 2012 Thought so Les - no way of telling unless I strip it down again - should have put the whole lot back with Velcro. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 4, 2012 Share Posted February 4, 2012 Here's one Uncle Les prepared for me earlier Quote Link to comment Share on other sites More sharing options...
Frax Posted February 4, 2012 Author Share Posted February 4, 2012 Must be a lot of it about - Did not know that Les was so artistic Quote Link to comment Share on other sites More sharing options...
stuck Posted February 4, 2012 Share Posted February 4, 2012 How the hell did it run like that?! Quote Link to comment Share on other sites More sharing options...
Frax Posted February 4, 2012 Author Share Posted February 4, 2012 Dont know but it did not sound bad - just goes to show what these engines will put up with. Quote Link to comment Share on other sites More sharing options...
Frax Posted February 8, 2012 Author Share Posted February 8, 2012 Still waiting on oil seal but I did remove the old one today and it was ripped, When I took the timing cover off I noticed that my new belt is running against the timing cover, I know it was all the way on the pulley when fitted and my tensioner's are new. Is there anything I need to check before I fit the new seal (when it arrives) all pulleys feel OK. When I did it the first time I do notice that the original belt had been doing the same thing. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 8, 2012 Share Posted February 8, 2012 I can't tell from the picture but does your crankshaft gear have the raised edges ? Quote Link to comment Share on other sites More sharing options...
Frax Posted February 8, 2012 Author Share Posted February 8, 2012 No its just a parallel with no edge....... Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 8, 2012 Share Posted February 8, 2012 Sounds like you have half of one kit and half of another. As I understood it you had either a raised edge on the idler and none on the crankshaft gear on the early kit and this got changed to a raised edge on the crankshaft gear and none on the idler to try and correct the timing belt issues that were occuring. Quote Link to comment Share on other sites More sharing options...
Frax Posted February 8, 2012 Author Share Posted February 8, 2012 That would be just my luck. I will have to look into that. I did think of making a large washer for the cam shaft pulley but would be better with the correct pulley. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 8, 2012 Share Posted February 8, 2012 This should be like your crankshaft gear (Part No LHH100660) normally supplied as part of STC4096K timing kit The Bearmach gear is better than the genuine Land Rover one as it is a one part gear whereas the Land Rover one has the sides spot welded on. Quote Link to comment Share on other sites More sharing options...
Frax Posted February 8, 2012 Author Share Posted February 8, 2012 Thank you for that, will order one but I will have to put the whole thing back together again if the seal turns up and then wait for the new gear, who if anyone does next day delivery. Quote Link to comment Share on other sites More sharing options...
Frax Posted February 8, 2012 Author Share Posted February 8, 2012 Ordered the Bearmach one for LRDirect so may see it turn up in a week or two. Thank you for your help CwazyWabbit. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 8, 2012 Share Posted February 8, 2012 No probs, I bet you wish you'd knocked up your crankshaft locking tool already Quote Link to comment Share on other sites More sharing options...
sharpy Posted February 9, 2012 Share Posted February 9, 2012 just for further info, i have sorted my poor pulling power on my 1987 90 with a disco 200tdi and it relates to this. today i bought from paddocks a new lift pump on the advice of the garage as their supplier wanted twice as much money. on dropping it off to the garage the owner said he had a similar problem and it wasnt until he installed his forth one that came with a spacer, as did mine. apparently Bob at paddocks was aware of this aswell and agreed with the garage, the replacement one should come with a spacer that keeps the lift pump another centimetre away from the block, apparently if you install a lift pump without it after a while it will bend the arm that enters the engine and in my case resulted in my loss of power as it was only getting half the fuel it should. Dont know what you guys think about this? but my poor starting has gone, and she pulls like a train on speed! seriously on the return from the garage I couldnt find a road long enough!!! approaching 60 in fourth with still a sh** loads left, im looking forward to tomorrow ;-) Paul Quote Link to comment Share on other sites More sharing options...
Frax Posted February 9, 2012 Author Share Posted February 9, 2012 Great result but have never heard of that before - will watch with interest to see if anyone else has. Quote Link to comment Share on other sites More sharing options...
sharpy Posted February 9, 2012 Share Posted February 9, 2012 not sure if this is clear? but you can quite clearly see the black spacer sandwiched between blue gaskets, i cant seem to make it any bigger (story of my life?) but this is from somewhere called Brookwells, there are a few if you google them, but like i said, worked for me Paul Quote Link to comment Share on other sites More sharing options...
