Mutley Posted February 8, 2012 Share Posted February 8, 2012 I was removing the crank breather ERR1471 and yes it broke!...just at the O ring point.... Now there is just enough to fit in the hole and i can bolt it back in place, obviously the seal without the O ring isn't going to be great, but would it be ok to do this and run the motor till i get a replacement breather? Cheers Mutley Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 8, 2012 Share Posted February 8, 2012 It'll make a bit of a mess but you should be alright... might be worth smearing some instant gasket on the stub before shoving it in. How far and what type of driving will you be doing? Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 8, 2012 Author Share Posted February 8, 2012 3 miles to work, 3 miles back and slowly Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 8, 2012 Share Posted February 8, 2012 I think you'll be fine Quote Link to comment Share on other sites More sharing options...
pete3000 Posted February 8, 2012 Share Posted February 8, 2012 like this one off the bay ? http://www.ebay.co.uk/itm/landrover-Cyclone-Engine-breather-200-300tdi-ERR1471-/220647869148 £12.75 + £2.50p+p Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 8, 2012 Author Share Posted February 8, 2012 Yep the same got one on order, but really need the motor till it arrives, if not a good idea to run it then so be it, just makes life a bit dificult Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted February 8, 2012 Share Posted February 8, 2012 It's only a breather and most leak anyway. As long as you can seal it enough to keep as much big stuff from getting in as possible then you will be fine. Quote Link to comment Share on other sites More sharing options...
