isbjorn Posted February 23, 2012 Share Posted February 23, 2012 (edited) Hi. Im registering my 1984 OneTen pickup and its converted with a 200tdi. Now I need a paper stating the engine size of my 200tdi engine. Does anyone have a pdf or similar that I can use. From land rover is grate, but it works with any type of paper saying that my engine type has this amount of Hp or similar. So nothing fancy, just a paper. A print of the instruction manual should work fine apparently. Engine 200tdi, 12L219384 Also I'm looking for a paper stating the fuel tank capacity. Also a print of a manual should work fine. The size is not so important just that anything is stated, and that its a One Ten or a 110 hc. I don't have anything so any tips or links are welcome. Many thanks. Misstype in the subject, 200tdi, not 300 Edited February 23, 2012 by western Quote Link to comment Share on other sites More sharing options...
Jim1 Posted February 23, 2012 Share Posted February 23, 2012 When i converted my 1988 to a 300tdi I took the engine number to the garage who did the MOT asked them to add details to receipt sent to DVLA with log book requesting the change came back all done. My 110 has 18 gal. tank as standard. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 23, 2012 Share Posted February 23, 2012 Given isBjorn is in Sweden, I expect he knows the procedures better than we do Quote Link to comment Share on other sites More sharing options...
stuck Posted February 23, 2012 Share Posted February 23, 2012 Is a quote from Wikipedia sufficent for your needs? http://en.wikipedia.org/wiki/Land_Rover_engines#200Tdi_.28Engine_Code_11L.29 Quote Link to comment Share on other sites More sharing options...
western Posted February 23, 2012 Share Posted February 23, 2012 would a copy of the Defender spec 200tdi repower kit leaflet help, it shows the engines bhp/torque, fuel tank size on all 110 is 80 litres the later plastic Td5 tank is slightly smaller capacity IIRC. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 24, 2012 Share Posted February 24, 2012 Maybe page 9 of this PDF can help with engine specifications? Chris Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 24, 2012 Share Posted February 24, 2012 Page 520 of this spare parts catalogue PDF describes the fuel tank as being 18 gallons. 1 imperial gallon is 4.54609188 litres. HTH Chris Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 24, 2012 Share Posted February 24, 2012 Page 164 of this PDF of the 1997 Defender Owner's Manual (marked on the page as page 161) also has fuel tank size mentioned. It says 'usable capacity' as 17.5 gallons, about 2270ml less than 18 gallons which sounds reasonable if you assume that the fuel pick-up cannot make use of the last 2270ml in the tank. HTH Chris Quote Link to comment Share on other sites More sharing options...
Lars L Posted February 24, 2012 Share Posted February 24, 2012 Being in Sweden and having done almost the same thing, even if it was back in 2002, the local SBP accepted the information in my Land Rover workshop manual. But that was when registering a 110 with 2,5n/a. Didn't tell them after the engine was swapped to a 200Tdi since they don't have a clue anyhow what the different engines look like... So with any kind of luck, they will accept just about anything written that looks a bit serious. Quote Link to comment Share on other sites More sharing options...
isbjorn Posted February 25, 2012 Author Share Posted February 25, 2012 So with any kind of luck, they will accept just about anything written that looks a bit serious. Hehe, thats the impression I got when I spoke with them. Super many thanks for the replays. The parts pdf is perfect as a tank size proof. And that it says the years they will love it. Makes it easy for them to understand. About the engine, the workshop manual is fine, but I'm a bit nervous they will say, why is not 12L mentioned anywhere. Since they don't care about the engine model name and the 200tdi is states as a 11L in the wikitext. I will give it a try thou and report back. Quote Link to comment Share on other sites More sharing options...
western Posted February 25, 2012 Share Posted February 25, 2012 11L = Defender specification 200Tdi with the high mounted turbocharger the 12L = Discovery spec 200Tdi with the low mounted turbo, which is in the same place as the later 300tdi engines. cubic capacity for all Tdi regardless of model is 2495cc or 2.5 litres Defender has 107 bhp & 188lb/ft torque Discovery has 111bhp & 195lb/ft torque otherwise they are the same except for various detail fitments like timing cases shape, PAS pump/Altenator mountings. Quote Link to comment Share on other sites More sharing options...
