discomikey Posted April 11, 2012 Share Posted April 11, 2012 does anyone know where i can get a pair. the 3.54:1 diffs and 235/85 tyres mean that setting off uphill with a trailer can make even Brian struggle a bit. the cruising at speed, however is unbeatable for a series. im guessing they were in some sort of rover car rather than a land rover but someone on here might know at least what they came from. its a shame i do so much towing really as its a toss up between very quiet motorway miles and setting off with a trailer on. :S Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted April 11, 2012 Share Posted April 11, 2012 If your not looking for decent aftermarket ones like KAM or Ashcroft then you need to be looking at an Early MG roadster (not sure what their properly called) some of these had 3.9 ratio rover diffs Steve Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 11, 2012 Share Posted April 11, 2012 And rover 3.0 coupe at 3.9 : 1 too Quote Link to comment Share on other sites More sharing options...
discomikey Posted April 11, 2012 Author Share Posted April 11, 2012 Cheers no I'm not looking for super expensive kam ones Quote Link to comment Share on other sites More sharing options...
ian_s Posted April 12, 2012 Share Posted April 12, 2012 could you not have a second set of rims and tyres for when you want to do towing? swapping between 205r16 and 7.50r16 tyres used to make a massive difference on mine, and that was with the 2.25d or you could shift into low range only for pulling away on a hill, though if you have freewheel hubs that mean a massive torque going only to the rear axle. and if you don't have them, you could end up winding the transmission up a bit Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted April 12, 2012 Share Posted April 12, 2012 I don't think MGB diffs will go into a Land Rover axle. The early versions your refer to are from the banjo axle type, and appear very different from the Rover type! You would be better off sourcing Rover car diffs as the housing lengths will be correct. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 12, 2012 Share Posted April 12, 2012 3.0 Coupe LN 3.9 3.5 V8 4 Dr 3.54 Coupe diffs are rare and spendy as a Ashcroft HD ! Nige Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted April 12, 2012 Share Posted April 12, 2012 I know the mg diffs are different but thought the cwp's were the same? I am not saying I'm right by any means! They're probably made of cheese the same as 4.7 series cwp's in any case. Personally I'd buy the Ashcroft ones, at least they're not 30 years old and pitted/worn out. I currently have Kam 3.8's, they are an excellent ratio for multi tasking on a Land Rover Quote Link to comment Share on other sites More sharing options...
discomikey Posted April 12, 2012 Author Share Posted April 12, 2012 Cheers Inge. Brian's wearing 3.54s now which are a bit high. Although I've realised today that my injectors might need a service which may be half the problem. Wen I slacked off the injector pipes the first 2 cylinders didn't make as much of a miss as the last 2. As my engine was sat for a few months after the crash then started to have light use. I think my injectors might have just been gunked up due to the amount of overfuelling. I'll try sticking some redex in the tank and tugging as much as possible about at full bore for about 10 miles and see if it gets any better. This can make a difference as it did with our mf 135. Quote Link to comment Share on other sites More sharing options...
