mcc1979ian Posted June 16, 2012 Share Posted June 16, 2012 ok so iv got all the wiring connected for the 200 tdi (disco engine) but it dont seem to wanna crank, iv got second stage power as i can get the wipers to run (slowly) have checked the battery and both yellow and red optimas are both around 6 to 6 1/2 volts so was thinkin o attching the jumper pack to see if this mite work. Have had the charger plugged in for 3 days to the red optima but instead of charging its lost 0.1 volts. does anyone know if there mite be a reason for them not charging with the trickle charger? is there anything stupidly obvious i could have missed with the wiring? do i just plain and simply have a flat battery? Quote Link to comment Share on other sites More sharing options...
simonr Posted June 16, 2012 Share Posted June 16, 2012 Sounds like just a flat battery. Try removing the starter battery and leaving it over night connected to a proper battery charger, not a trickle charger. If in the morning it still reads less than 12v with the charger disconnected, the battery is damaged. Take it so someone with a battery tester (Halfords) to check. Si Quote Link to comment Share on other sites More sharing options...
ejparrott Posted June 16, 2012 Share Posted June 16, 2012 If the wipers are turning very slowly, and you've only got 6.5 volts at the batteris, it looks like the batteries are toast. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted June 16, 2012 Share Posted June 16, 2012 Very flat and i would think very knackard batteries at 6 volts. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 16, 2012 Author Share Posted June 16, 2012 they have just been lyin around the garage for the last 2 years so im hoping this mite be the reason they so flat, heres hopin anyway Quote Link to comment Share on other sites More sharing options...
western Posted June 16, 2012 Share Posted June 16, 2012 they might recover from the low charge state, a Ctek charger with a recondition selection on it would help one of these or a similar unit http://www.ctek.nu/gb/en/chargers Quote Link to comment Share on other sites More sharing options...
eds Posted June 16, 2012 Share Posted June 16, 2012 check this out difficult to believe but def worth trying Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 16, 2012 Author Share Posted June 16, 2012 its worth a try, has to be better as spendin nigh on £400 for 2 batteries if that mite work. Quote Link to comment Share on other sites More sharing options...
