muddy4x4xfar Posted June 18, 2012 Share Posted June 18, 2012 hi all. iv got a 200tdi disco, it has standard suspension, would a set of 265/75/r16 bf goodrich tyres go on with no modifications? also if i was to go down the road of having a suspension lift whats everybodies recommendations. i do go offroading but also do a lot of offroading driving. cheers Quote Link to comment Share on other sites More sharing options...
fozsug Posted June 18, 2012 Share Posted June 18, 2012 Would need a Camel Cut minimum. 2" inch lift Gwyn Lewis OME Kit. Quote Link to comment Share on other sites More sharing options...
godzilla84 Posted June 18, 2012 Share Posted June 18, 2012 Not even with a camel cut. I managed 235/85/16 BFG AT with just a camel cut but i tried 265s and they rubbed quite badly. The other issue is what offset wheels are you planning on using? Standard disco wheels will rub the radius arm on full lock with that tyre size. Stick them on a set of modulars and that overcomes that issue. Quote Link to comment Share on other sites More sharing options...
fozsug Posted June 19, 2012 Share Posted June 19, 2012 Funny im running 265/75/16 Kuhmo KL71's on Wolf rims and a Camel Cut, adjusted stops, but no excessive rubbing at all. Quote Link to comment Share on other sites More sharing options...
godzilla84 Posted June 19, 2012 Share Posted June 19, 2012 what offset are wolf rims? Quote Link to comment Share on other sites More sharing options...
fozsug Posted June 20, 2012 Share Posted June 20, 2012 what offset are wolf rims? Not a clue , sorry Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 20, 2012 Share Posted June 20, 2012 Wolf rim offsets info - http://forums.lr4x4.com/index.php?showtopic=64189 Quote Link to comment Share on other sites More sharing options...
disco_al Posted June 20, 2012 Share Posted June 20, 2012 i'm using 235/85/16 bfg at's without a camel cut, and not suffering from any rear end rubbing problems that's with bearmach HD rear springs all round. they do catch on the n/s radius arm though, so stop needs tweaking a bit Quote Link to comment Share on other sites More sharing options...
Maverik Posted June 20, 2012 Share Posted June 20, 2012 i'm using 235/85/16 bfg at's without a camel cut, and not suffering from any rear end rubbing problems that's with bearmach HD rear springs all round. they do catch on the n/s radius arm though, so stop needs tweaking a bit Do the HD springs give a lift? Quote Link to comment Share on other sites More sharing options...
Stevie D Posted July 3, 2012 Share Posted July 3, 2012 Do the HD springs give a lift? Normally about 20-30 mm! Quote Link to comment Share on other sites More sharing options...
