mcc1979ian Posted July 2, 2012 Share Posted July 2, 2012 morning all, i need to split my gearbox and transfer box as iv sold the gearbox, but the question is do i need to drain the oils before splitting or can it be done later? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 2, 2012 Share Posted July 2, 2012 Maybe drain the transfer box, the gearbox is self contained but the transfer box may leak out once you have removed the gearbox input shaft from it as the seal won't have anything to seal against! ....... depends which way up you keep it really Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted July 2, 2012 Share Posted July 2, 2012 2 of the. bolts that hold the tfer to the main box are through bolts-when you remove them the Ep90 from the tfer box dribbles out-so yes better to drain first. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 3, 2012 Share Posted July 3, 2012 Bugger, I forgot about those two bolts Rusty. Good job someone was awake Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted July 3, 2012 Share Posted July 3, 2012 I think most of us learn the hard way that the transfer box definitely needs to be drained Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 3, 2012 Share Posted July 3, 2012 I think most of us learn the hard way that the transfer box definitely needs to be drained Yep Quote Link to comment Share on other sites More sharing options...
