dirtyninety Posted July 6, 2012 Share Posted July 6, 2012 Hi there, very occasionally my 02 plate td5 90 lets out a squeal when the turbo comes into boost, is this anything i should be concerned about? Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted July 6, 2012 Author Share Posted July 6, 2012 Also, maybe a completely unrelated issue, sometimes i can plant my foot, then perhaps 10 or even 20 seconds can pass before any noticeable power, i am presuming this is turbo lag, it can be fine for months then gutless for a couple of days then normal again. My 90 has had a decat pipe, which i thought would improve the turbo lag. bl**dy temperamental land rovers. (cannot edit my first post, it brings up an error, server issue?) Quote Link to comment Share on other sites More sharing options...
Tanuki Posted July 6, 2012 Share Posted July 6, 2012 I'd check that you haven't got a split in one of the turbo-hoses. These can squeal/hiss when the pressure builds up and the air starts escaping. If the hose has delaminated internally a 'flap' of rubber can also balloon up inside under pressure and inhibit the air-flow. --Tanuki Quote Link to comment Share on other sites More sharing options...
M&S Posted July 6, 2012 Share Posted July 6, 2012 Try unplugging the MAF sensor and see if that helps with the turbo lag. When my sensor was faulty last it caused that problem. Have you only noticed the whistle since fitting the decat pipe? Could be a warped manifold. I "lost" my rear silencer and notice my turbo whistle a bit now when I'm heavy with the right foot, so it may just be the loss of the cat? Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted July 6, 2012 Author Share Posted July 6, 2012 its not so much a whistle, ive got a straight though mid pipe and turbo whistle and whine is much much different to this. Its like a loud squeal almost like a raspy super charger. I'll unplug the MAF sensor and see what happens. Thanks, and i shall report back! Quote Link to comment Share on other sites More sharing options...
landy andy. Posted July 6, 2012 Share Posted July 6, 2012 I think you have a warped exhaust manifold. Check the studs on each end of the manifold, and I think you may find them snapped. Lack of power till later in rev range is classic MAF fail Andy Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted July 6, 2012 Author Share Posted July 6, 2012 I inspected the exhaust manifold for leaks and snapped studs, and it appears to be perfect and intact. I can my hand around it and felt for leaks when it was cold, and after a drive. Ive unplugged the MAF and it made my engine completely unresponsive for 20 or so seconds, i presume this is normal and the ECU is altering itself to new parameters. Driving with the MAF disconnected has made no noticeable difference in performance. Perhaps my MAF is so dead that its inoperational even when its connected, if you know what i mean? I shall pick up a brand spanker tomorrow, its always good to have a spare with 3 TD5's in the family. Another thing i forgot to mention, when i start the engine from cold and hold my engine at quarter revs, it plumes and plumes thick white smoke. After ive driving for say a minute and the engine is slightly warmer it doesnt do it. Suggestions? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 6, 2012 Share Posted July 6, 2012 I'm not sure what the layout of the Td5 is... but I had a squeely turbo noise when the breather-thingy hose came off the top of my engine. Quote Link to comment Share on other sites More sharing options...
Julian Posted July 6, 2012 Share Posted July 6, 2012 Another thing i forgot to mention, when i start the engine from cold and hold my engine at quarter revs, it plumes and plumes thick white smoke. After ive driving for say a minute and the engine is slightly warmer it doesnt do it. Suggestions? Well missing that point out is a bit like phoning NHS direct and saying 'I'm feeling a bit lightheaded, what should I do?' but omit the fact that there's 3 pints of blood on the floor c/o a 50 calibre slug in your leg :-) Obviously that noise from the turbo and that smoke indicated that the turbo is dead - seizing up/shot bearings/worn seal.... Quote Link to comment Share on other sites More sharing options...
