Richy B Posted July 15, 2012 Share Posted July 15, 2012 Hi there, I require 4x 30mm diameter steel round bar with 10mm drilled n tapped holes in each end of the bar to a depth of 25mm , length 11 cm these are for a rear storage build in a 90 ( pics when finished ) can anyone on here build them for a sensible fee please ???? Many thanks Quote Link to comment Share on other sites More sharing options...
zim Posted July 15, 2012 Share Posted July 15, 2012 Where in the UK are you ? Quote Link to comment Share on other sites More sharing options...
Richy B Posted July 15, 2012 Author Share Posted July 15, 2012 Oops !! Always forget that bit :0) I'm in Oakley, Hampshire, (Nearest big town is Basingstoke ) I don't mind paying a proper price and postage or adoration to the forum if that tips the scales ?? Thank you Quote Link to comment Share on other sites More sharing options...
02jcole Posted July 15, 2012 Share Posted July 15, 2012 I can do it if no one else wants to. PM me if your interested and I'm sure we can work out a fair deal Quote Link to comment Share on other sites More sharing options...
Julian Posted July 16, 2012 Share Posted July 16, 2012 You could drill in a pillar drill and tap by hand. maybe use aluminium if strength isn't an issue? Julian. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 16, 2012 Share Posted July 16, 2012 Are you supplying the material? I could do it one night after work. Quote Link to comment Share on other sites More sharing options...
steve b Posted July 17, 2012 Share Posted July 17, 2012 you could also weld a nut to a washer then weld the washer to the ends of a piece of 30 dia tube , nuts on the inside = no machining + lighter too cheers Steveb Quote Link to comment Share on other sites More sharing options...
