straightshooter Posted August 2, 2012 Share Posted August 2, 2012 Hi all I thought I would ad a post about my Bobtail project swaped it some time ago for an old mercedes which I used to own about ten years ago couldn't believe it was for sale when i saw it so impulse bought it! but quickly descovered that I have no use for a normal car like this which 10 years ago I really liked so it was up for sale after just 3 weeks but couldn't sell her for love nor money well descent money so i messaged a few people who were selling there 4x4's who where looking for a swap and befor eyou know it I had a good few people interested but this one just pulled on my heart strings I have owned a few of these beasts in the past but never a bobtail so i thought what the hell another project would keep me out of trouble so here she is: as you can see she had a bit of a bump at the front also where she was bobtailed she had mastic put into the join which looked terrible but over all the chassis is solid and the convertion as a whole isn't bad had lots spent on her including suspension work and engine mods she just needs finishing off so with no further ado I had to crack on and fix the bonnet wing and the joins on the rear panels and here she is so far the roll cage has been removed re welded as the welding was not the best and shot blasted then painted with a textured rubberized paint which looks great in fact i intend to use this stuff on the pillars and the inner doors great stuff, but expensive. and she has been completely rubbed down the colour has been purchased (it was the closest match to what i decided and found 5 liters on flea bay for £40 which is really cheap) and the rear end of the truck has been painted thought i would post a few pics exscuse the pictures but they were taken with my iphone next job is to weld the rollcage on then paint the front then a few odds and **** and she should be ready to play here are some more pics with all the masking off roll cage back on next week and the rest of the panels so should be back together by the end of the following week :good: and a shot of the engine bay by the way this hasn't even been flattened yet :good: well guys nearly there the roll cage has been welded back on and the front end painted and assembled and spots mounted on the roll cage just a few more finishing touches to be completed on the outside like painting the rock sliders and finishing the rear quarter panel then it's just the interior that need s to be completed and she'll be ready for action here are some more pictures just a couple more pictures if anyone is interested got the decals on the bonnet and spray the rock sliders the interior roof lining has been recovered and fitted but forgot to take a picture will get one up shortly still need a windscreen also need to get some floor covering for the interior and some checker plating for the door cards but funds are short so the project will grind to a halt for the moment Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted August 2, 2012 Share Posted August 2, 2012 I'm thinking that cage could do with a bit of work around the middle, i.e support from the cage to chassis imho Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 2, 2012 Author Share Posted August 2, 2012 in fact it used to have the support to the middle pillars but I removed them as you can see from the pictures above but these were a waiste of space and looked terrible I have been considering either installing an internal rollcage and connecting them through the roof or two pipes conecting from the rollcage to the rock sliders externally undecided as of yet Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 3, 2012 Share Posted August 3, 2012 You've made great progress since you bought it! Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 3, 2012 Author Share Posted August 3, 2012 You've made great progress since you bought it! many thnaks it's been hard work but I think the results should be worth it Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 7, 2012 Author Share Posted August 7, 2012 one of the meembers mentioned that i needed support in the centre of my cage which i totally agree and I have been toying with various options ie internel then conecting throught the roof either bolting throught the roof or drilling a hole through or the option in the picture below conecting bar from the roof to the sliders I wont be using the rear doors anyway what are the thoughts out there? Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted August 7, 2012 Share Posted August 7, 2012 if your not going to use the rear seats then ideally an internal cage done well would provide the best protection imho Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 7, 2012 Author Share Posted August 7, 2012 ok any more for any more???? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 8, 2012 Share Posted August 8, 2012 Roll hoop behind driver, holes cut into the rear seat box to allow you to weld on saddles to the chassis, 5mm plate minimum. Two diagonal cross-braces in the hoop, going right from the saddles to the top corner as much as practicable. Two diagonal cross braces going from the top of the roll hoop to as far back as practicable in the load area -you may want to shorten them a bit if you intend to carry anything, for MSA compliance I think they need to be directly into the chassis rails, however on my previous cage I built outriggers at the rear of the chassis, very well braced, which seemed to work OK (although I never rolled it ) Anywhere you attach anything to the chassis, plate it up with 5mm beforehand. Tube can be blue band or CDS, CDS you can get away with 2.64mm wall, BB 3.2, tube at least 1.75" (45mm) diameter. Does that help? Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 8, 2012 Author Share Posted August 8, 2012 Roll hoop behind driver, holes cut into the rear seat box to allow you to weld on saddles to the chassis, 5mm plate minimum. Two diagonal cross-braces in the hoop, going right from the saddles to the top corner as much as practicable. Two diagonal cross braces going from the top of the roll hoop to as far back as practicable in the load area -you may want to shorten them a bit if you intend to carry anything, for MSA compliance I think they need to be directly into the chassis rails, however on my previous cage I built outriggers at the rear of the chassis, very well braced, which seemed to work OK (although I never rolled it ) Anywhere you attach anything to the chassis, plate it up with 5mm beforehand. Tube can be blue band or CDS, CDS you can get away with 2.64mm wall, BB 3.2, tube at least 1.75" (45mm) diameter. Does that help? excelent fancy giving me a hand LOL! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 8, 2012 Share Posted August 8, 2012 To far away really P&P will do you the hoop and everything you need, ring them up and ask them Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 8, 2012 Author Share Posted August 8, 2012 cheers bud will do Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted August 10, 2012 Share Posted August 10, 2012 Mine is a P&P cage with internal hoop. You'd only need to add the hoop. And I can have my seat all the way back with people in the back. Getting in and out the back is a squeeze though. Mainly because of the rear diagonals. Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 10, 2012 Author Share Posted August 10, 2012 Mine is a P&P cage with internal hoop. You'd only need to add the hoop. And I can have my seat all the way back with people in the back. Getting in and out the back is a squeeze though. Mainly because of the rear diagonals. now thats what I am talking about so what sort of price am i looking at for something like that??? in fact all i would need is the internal hoop and the connectors Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted August 15, 2012 Share Posted August 15, 2012 I forget as it was a few years ago but it was about £700 I think. It was a special though because of where I wanted the main hoop and the rear diagonals. Best bet would be to give them a ring as just the main hoop would probably be pretty cheap. They have an ebay page too. http://stores.ebay.co.uk/Protection-And-Performance-Ltd?_trksid=p4340.l2563 Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 15, 2012 Author Share Posted August 15, 2012 cheers bud will do Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 17, 2012 Share Posted August 17, 2012 regarding the inside / outside question - definately inside. vertical cage tubes just catch on everything in sight. Not ideal if you are trying to progress in a forwards direction! Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 20, 2012 Author Share Posted August 20, 2012 I agree bud I think and internal hoop from P&P when funds allow will be the way I will go Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 22, 2012 Author Share Posted August 22, 2012 well chaps just a quick update it's the first MOT tommorrow since doing the wor on here so fingers cossed Quote Link to comment Share on other sites More sharing options...
straightshooter Posted August 23, 2012 Author Share Posted August 23, 2012 :i-m_so_happy: :i-m_so_happy: she passed with flying colours not one advisory :i-m_so_happy: :i-m_so_happy: just had to lean her out a bit as she was running very rich my fault setting the edelbrook carb by ear Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted August 28, 2012 Share Posted August 28, 2012 Well done Quote Link to comment Share on other sites More sharing options...
