4x4landy Posted August 24, 2012 Share Posted August 24, 2012 I managed to break mine while swapping out my turbo . Thinking of replacing them all with silicone . Any idea what internal mm hose I need ?? 3 /5mm ?? Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 24, 2012 Share Posted August 24, 2012 Same as the original I would guess. But I don't think the soft silicone pipe is suitable. The original is hard plastic. I would try to get something of the same strength and heat resistance. Quote Link to comment Share on other sites More sharing options...
4x4landy Posted August 25, 2012 Author Share Posted August 25, 2012 Yeah trying to work out what mm it is . And why wouldn't silicone be suitable ? Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 25, 2012 Share Posted August 25, 2012 Silicon gets soft when warm and that hose works on a vacuum so would likely squeeze flat. Hence the use of rigid plastic. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 25, 2012 Share Posted August 25, 2012 Silicon gets soft when warm and that hose works on a vacuum so would likely squeeze flat. Hence the use of rigid plastic. I thought that pipe was under pressure when turbo is blowing, not a vacuum Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 25, 2012 Share Posted August 25, 2012 Hmm, maybe you are right. Always assumed it was a vacuum for some reason (throwback to carburetor days) Quote Link to comment Share on other sites More sharing options...
fozsug Posted August 25, 2012 Share Posted August 25, 2012 Which pipe/pipes are you talking about? The pipe from the fuel pump to the turbo, which as said above is ridgid plastic and should be replaced with the same, its only £ 15.00 genuine LR. Or are you talking about the pipes from the turbo to the intercooler and inlet manifold, which do benifit by being change to Silicon pipes.? Quote Link to comment Share on other sites More sharing options...
4x4landy Posted August 25, 2012 Author Share Posted August 25, 2012 The small one that goes from pump to turbo . Why can't it be silicon?? I mean on a rs turbo there silicone ?? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 25, 2012 Share Posted August 25, 2012 they can be anything you like as long as it will hold the pressure and is oil resistant.. Washer jet hose has worked for me in the past. Quote Link to comment Share on other sites More sharing options...
4x4landy Posted August 25, 2012 Author Share Posted August 25, 2012 Vulcan just what I was thinking . I'm sure on my dads 300 it's got clear washer hose for a section of it . Going to order a new 2m length of blue or black silicone and a new boost gauge ! Quote Link to comment Share on other sites More sharing options...
