Fatboy Posted November 4, 2012 Share Posted November 4, 2012 Morning Gents! While i wait on some parts, I'm having a major sort out and getting bits together for the imminent assembly on the 110. (Must start a build thread). I've got: 1. A good condition, standard Range Rover V8 auto radiator which has built in tanks either side for engine and gearbox oils and the standard bog brush oil cooler that went with it. 2. A bullet proof HD, radiator which was built for a 90 that has a built in tank for engine oil cooling only. I assume the Range Rover configuration helps the gearbox oil get to temp quicker because it is alongside the water and keeps it steadier for the same reason? I'd rather use the bullet proof rad and could either use the bogbrush on its own or buy another oil cooler and fit it in front of the rad but would this be sufficient? I guess I could hook a temp gauge on or thermostat and use a fan if the box gets warm or should I use the RR system because of the warm up function? Any thoughts? Thanks, Donald Quote Link to comment Share on other sites More sharing options...
zardos Posted November 4, 2012 Share Posted November 4, 2012 You could also buy a Laminova oil to water cooler to emulate the RR system but with using the HD Rad I use a C43-330 for my auto box (http://www.thinkauto.com/acatalog/On_line_shop_C43_Engine___transmission_cooler_18.html) Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 6, 2012 Author Share Posted November 6, 2012 Thanks for the reply, that may be a bit spendy for me at the moment, I think I'll install a temp gauge to start with and see how it goes. (I've yet to build the engine so it's a long way away yet!) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 7, 2012 Share Posted November 7, 2012 I've stuck temperature indicating labels over my 4.6 (no oil cooler), so far nothing's got hot enough to worry about. (Stuck one on the sump, one on the oil filter, one on the top hose, one on the bottom hose) Quote Link to comment Share on other sites More sharing options...
Daan Posted November 7, 2012 Share Posted November 7, 2012 Tell me more about your bullet proof rad. I didn't realize this exist. daan Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 7, 2012 Author Share Posted November 7, 2012 Daan, I bought it from Nige a while back, the fins like like deck grating and would probably dice anything that hit them.... Would you like a photo? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 7, 2012 Share Posted November 7, 2012 I got one like that, very wide fin spacing, fat cores, holds loads of water, never clogs: Core is from an earthmover, made to spec by Wessex Rads. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 7, 2012 Author Share Posted November 7, 2012 Fridge, I was focussing on the gearbox but you've raised a good point... What gearbox do you have in your wagon? Mine is going to be a ZF so I've got input and output hoses that need to go somewhere. If the 4.6 is happy without the oil cooler on the rad, I could use that chamber for the gearbox therefore it will have its temp assisted by radiator water. (The engine oil gets that anyway I suppose). Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 7, 2012 Share Posted November 7, 2012 Mine's R380. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 7, 2012 Share Posted November 7, 2012 I would have thought that the autobox will be working harder in the 110 than it would in a RRC due to weight and aerodynamics so will need more cooling than the only-just-sufficient- bog brush. Better to be over cooled than to cook your box (so to speak ) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 8, 2012 Share Posted November 8, 2012 But a RR weighs more than a 110 doesn't it? There's half a ton of extra soft furnishings at least... Quote Link to comment Share on other sites More sharing options...
