ponnyj Posted February 14, 2013 Share Posted February 14, 2013 Hi guys. Just wanting a little help with diagnosing a problem I'm having with the trip on my 300tdi 130. It seems to be reading about 80% of the actual miles traveled. I've just noticed as I've done 600idh miles this week with work (worked out on google) and the trip is showing 450 or there abouts. Wondering. If anyone has had this before. Could it be the speedo cable or something in the cluster?? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 14, 2013 Share Posted February 14, 2013 First thing, what size tyres are you running? If they're massive, it can mean its underreading on the speedo. I had similar when my speedo head was dieing... But it was acompanied by the speedo flicking right up and down when going along and stopping working sometimes. Quote Link to comment Share on other sites More sharing options...
ponnyj Posted February 14, 2013 Author Share Posted February 14, 2013 It's got 7.5 continental "offroad"'s on. Quote Link to comment Share on other sites More sharing options...
Escape Posted February 15, 2013 Share Posted February 15, 2013 It's not the tyre size then. Is your speed reading still acurate? Check with a GPS if you haven't already. If both are reading too low, it's probably the cable or wiring from the speed sensor. If the speed is correct, but trip (and total) aren't, it has to be internal to the speedo. Quote Link to comment Share on other sites More sharing options...
steve b Posted February 15, 2013 Share Posted February 15, 2013 300 Tdi s are cable driven speedo does it have the original transferbox? - if a Disco one has been fitted and the speedo drive gear not changed it'll under-read miles and speed Also if the rear tbox output shaft nut is not tight the speedo drive gear can slip on the shaft hth Steveb Quote Link to comment Share on other sites More sharing options...
SteveG Posted February 16, 2013 Share Posted February 16, 2013 As per Steve's post you can alter speedo gearing, so even if tyres are back to stock levels, if someone has changed gearing it will be out. Quote Link to comment Share on other sites More sharing options...
ponnyj Posted February 17, 2013 Author Share Posted February 17, 2013 Thanks for the replys guys. I'll check out the tbox and stuff soon as I get a chance. Quote Link to comment Share on other sites More sharing options...
