need4speed Posted March 13, 2013 Share Posted March 13, 2013 Looking at how im going to house EDIS, ECU and Relay Board this morning, and as such had my first real look at how the EDIS is configured. Pin 3 of the EDIS has this plug attached. No problem, as the MS guide says Pin 3 is IDM and i should just remove it as its not used. However, looking at the wiring diagram for the EDIS it says Pin 3 is SAW and that Pin 2 is IDM. The MS Wiring Diagram also shows Pin 3 as being a pink SAW wire going to Pin 36 of the D37 plug. Huge apologies if this has been discussed before but im a bit confused by this. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 13, 2013 Share Posted March 13, 2013 1 is Defo PIP - Slate and Orange on Wiring diagram and 3 is Defo SAW - Pink on diagram Pin 2 is not used its IDM My MS wiring Diagram shows correct. and D37 plug diagram shows correct connection it says pin 3 Nige Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 13, 2013 Author Share Posted March 13, 2013 Thanks for clearing that up Nige. Id have given you a call but didnt want to hassle you. Thought id give someone else a shot for a change So can i go ahead and snip that plug off, and extend the wire for SAW? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 13, 2013 Share Posted March 13, 2013 You may find the MS manual was written for EDIS4, which has the plug the other way round Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 13, 2013 Author Share Posted March 13, 2013 What the hell IS that plug? Cant i chop it off? Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 13, 2013 Author Share Posted March 13, 2013 Cant see it in any diagrams or pics - Its getting chopped. Quote Link to comment Share on other sites More sharing options...
Mr Noisy Posted March 21, 2013 Share Posted March 21, 2013 That little box could be some kind of IDM filter if it is the IDM line? i think the EDIS 4 had the same plug but the configuration was different?? ie EDIS 4 had a Clean Tacho Output aswell...? Quote Link to comment Share on other sites More sharing options...
cosecon Posted March 21, 2013 Share Posted March 21, 2013 Maybe I am talking nonsense, but I think it is just a bridge. If you remove it you just get 10 degrees safe mode. (works like this in my megajolt setup.) Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 21, 2013 Author Share Posted March 21, 2013 Its long gone.... Quote Link to comment Share on other sites More sharing options...
cosecon Posted March 21, 2013 Share Posted March 21, 2013 You will not have any problem. Quote Link to comment Share on other sites More sharing options...
