tonytiger Posted March 17, 2013 Share Posted March 17, 2013 My horn and full beam flash has stopped working... indictors and main beanlm constant work... any Bright ideas you wanna make some joise about! ! Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 17, 2013 Share Posted March 17, 2013 I had similar once. A new stalk cured it. Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2013 Share Posted March 17, 2013 I had a broken wire on mine which affected the same items, check the connections at the stalk are secure, they are push on terminals. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 17, 2013 Share Posted March 17, 2013 As Western says, check the feeds to the switches - they have their own feeds directly from the fuse box, unlike the indicator and normal dim/dip contacts. Check not only the security of the contacts but also their condition - look for dirt and corrosion; a dull grey surface on the terminals might not look too bad, but it can completely block the current, even though the voltage might read OK across the joints (resistance will not affect voltage until a demand is put on the system, at which point the resistance becomes effective and the voltage drops off - imagine the pressure at a tap with a very thin feed pipe; the presure at the tap will be at mains pressure until you open the tap, at which point the water flow is too restricted to keep up with demand and the pressure drops). Quote Link to comment Share on other sites More sharing options...
