JeffR Posted May 24, 2013 Share Posted May 24, 2013 The bloody handbrake has seized on the Disco (shouldn't have left it on for the past 6 months I guess....), despite a severe battering with a lump hammer, it will not come undone. All suggestions gratefully received. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 24, 2013 Share Posted May 24, 2013 Check it's not the cable that has siezed disconnect it then try your gentle! Tapping again. Mike Quote Link to comment Share on other sites More sharing options...
JeffR Posted May 24, 2013 Author Share Posted May 24, 2013 Check it's not the cable that has siezed disconnect it then try your gentle! Tapping again.Mike Never thought of that one! Cheers Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 24, 2013 Share Posted May 24, 2013 Back off the adjust nut on the back of the drum ? Quote Link to comment Share on other sites More sharing options...
JeffR Posted May 24, 2013 Author Share Posted May 24, 2013 Back off the adjust nut on the back of the drum ? seized solid........... Quote Link to comment Share on other sites More sharing options...
qwakers Posted May 24, 2013 Share Posted May 24, 2013 low range, 1st gear, drop the clutch. will either work or snap a UJ..... Quote Link to comment Share on other sites More sharing options...
landy andy. Posted May 25, 2013 Share Posted May 25, 2013 As mentioned, is often the cable. If so chock the wheels then cut cable. Andy Quote Link to comment Share on other sites More sharing options...
JeffR Posted May 25, 2013 Author Share Posted May 25, 2013 Squirted half a tin of plus gas down the cable tube last night, will leave it to soak till later on then carry on battering... Quote Link to comment Share on other sites More sharing options...
