easytiger Posted June 21, 2013 Share Posted June 21, 2013 Hi, I'm thinking of buying a 91 110 station wagon. It has a 2" lift on it, can anyone tell me whats involved in returning it to standard please? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 21, 2013 Share Posted June 21, 2013 Well, generally it involves taking off any non-standard parts and putting standard one back on in replacement... Potential parts that may have been changed: Springs most likely Shocks probably Shock mounts Suspension arms (radius arms etc.) Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 21, 2013 Share Posted June 21, 2013 Depends what has been changed .. ? Might just be springs, or springs and shocks, or springs and shocks and brake lines etc. Nothing difficult - nor expensive though. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 21, 2013 Share Posted June 21, 2013 Oops - beaten by speedy James ! In my defence - I've my Mum on the phone. In her defence - I should be paying more attention. Quote Link to comment Share on other sites More sharing options...
damanic Posted June 21, 2013 Share Posted June 21, 2013 Look to see if the+2 lift comes from spacers or longer springs. Check the radius and trailing arms to see if they are standard, they might have been castor corrected. Check the shock mounts are standard. After removing the lift check the shocks do not bottom out on full compression. Bumpstops might be longer than standard. Quote Link to comment Share on other sites More sharing options...
easytiger Posted June 21, 2013 Author Share Posted June 21, 2013 Thanks, I reckon that the truck will have larger wheels/ tyres, what is the biggest tyre size I could use with standard suspension set up? Quote Link to comment Share on other sites More sharing options...
damanic Posted June 21, 2013 Share Posted June 21, 2013 For going back to standard.. 235/85... if you want bigger tires keep the lift. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted June 21, 2013 Share Posted June 21, 2013 You can go 265/75 on standard but it'll give you a slightly smaller turning circle. Quote Link to comment Share on other sites More sharing options...
