Spongie Posted July 5, 2013 Share Posted July 5, 2013 Anyone know what thread engine mount rubbers on 200tdi disco use? Help I've got no nuts :-s Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 5, 2013 Share Posted July 5, 2013 If no answer by later I can check for you . Quote Link to comment Share on other sites More sharing options...
Spongie Posted July 5, 2013 Author Share Posted July 5, 2013 Please or otherwise I'm going to have to take the whole engine mounting rubber to local fixings/fastening place, which means removing it from the engine... A bit of a inconvenience! It's definitely not m10 as suggested on Facebook as it seems much larger and quite a fine thread Quote Link to comment Share on other sites More sharing options...
steve b Posted July 5, 2013 Share Posted July 5, 2013 I thought they were M16 std thread =24mm nut ? ..you are referring to the std Disco/RRC type mount and not the defender type? cheers Steveb Quote Link to comment Share on other sites More sharing options...
western Posted July 5, 2013 Share Posted July 5, 2013 http://www.numcat.ru/landrover/p/32/45301/ item 7 says M12 http://www.numcat.ru/landrover/p/32/45302/ item 5 also M12 Quote Link to comment Share on other sites More sharing options...
ballcock Posted July 5, 2013 Share Posted July 5, 2013 Could also depend on whether they are original or not, just changed my V8 ones and found the ones from Bearmach were M10 not M12 so my original nuts didn't fit. Quote Link to comment Share on other sites More sharing options...
Spongie Posted July 6, 2013 Author Share Posted July 6, 2013 Steve's estimate of m16 sounds about on par! I've taken one off and will run in to local hardware jobby tomorrow and see what they be Quote Link to comment Share on other sites More sharing options...
