dirtyninety Posted July 11, 2013 Share Posted July 11, 2013 Can anyone tell me how to open the bonnet on a discovery 2 that has a broken bonnet release cable? Quote Link to comment Share on other sites More sharing options...
utdiscoII Posted July 11, 2013 Share Posted July 11, 2013 Ughh, my hood(bonnet) release cable is broken at the end and I have to use a wrench to grasp it and open the bonnet right now. This is one overlooked part that should probably be upgraded/maintenance. Not goo when the problem presents itself on the trail. I am going to put a crimped loop on the end w/ shrinkwrap or the like, when I replace it (soon). Is it possible to get underneath up front and somehow loop the mechanism and pull it down from there? That might be the only option.... Interested to hear how you solve the problem. I'd look now but I am in J'lem and my Disco is in Utah. Best, Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted July 11, 2013 Author Share Posted July 11, 2013 Unfortunately the bonnet release is behind the grill, and then surrounded in an anti-tamper guard to stop people opening your bonnet! I have found the cable isnt snapped, but you cant pull it hard enough to pop the bonnet. I think the actual mechanism is siezed up. Not looking forward to this job. May be a case of cutting the grill out, and butchering the mechanism from underneath. carp. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 11, 2013 Share Posted July 11, 2013 If you think it is siezed can you not get a wd40 tube near it and soak the bugger? Quote Link to comment Share on other sites More sharing options...
teabag Posted July 11, 2013 Share Posted July 11, 2013 Unfortunately the bonnet release is behind the grill, and then surrounded in an anti-tamper guard to stop people opening your bonnet! I have found the cable isnt snapped, but you cant pull it hard enough to pop the bonnet. I think the actual mechanism is siezed up. Not looking forward to this job. May be a case of cutting the grill out, and butchering the mechanism from underneath. carp. You have had an extra pair of hands pressing down on the bonnet while u pull hard the release, haven't u? 1 Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted July 11, 2013 Author Share Posted July 11, 2013 Yeah tried everything, I have now got it open tho! Yay http://forums.lr4x4.com/index.php?showtopic=69786 The pdf at the bottom of this thread is very informative. You can poke two screw drivers through grill, poke them through the plastic cover and wiggle and prod unroll you hit the sweet spot. To be honest I sat for half an hour trying and gave up, my annoying mate spent two minutes and popped it open! The mechanism is free, but the spring is incredably strong, combined with a old cable (x reg) means you cannot open it. Going to order a new cable, and wd40/copper slip the mechanism so its as free as can be. So that's definitive proof, you CAN open a td5 disco bonnet from the outside, without cutting the grill. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 11, 2013 Share Posted July 11, 2013 Good find that pdf Quote Link to comment Share on other sites More sharing options...
teabag Posted July 11, 2013 Share Posted July 11, 2013 When mine jammed I pulled so hard I broke the T handle, but it opened as soon as the extra hands were placed on the bonnet. I only use the inner when replacing as there is a bit more work replacing the whole cable, so a well greased inner and a splash of engine oil on the lock and I haven't had this problem again, 9 years now. Quote Link to comment Share on other sites More sharing options...
JeffR Posted July 11, 2013 Share Posted July 11, 2013 Beg, steal or borrow a motorbike cable oiler, make up some runny copper grease and squirt that down the cable - makes a world of difference. Works on the handbrake cable too. Quote Link to comment Share on other sites More sharing options...
