weasel_110 Posted July 27, 2013 Share Posted July 27, 2013 Hi Peeps...Was going on holiday today but kenlowe fan blew and is seized solid...Does anyone have a spare viscous fan I could buy to get me out of the s**t? All shops are shut now CheersGary Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 27, 2013 Share Posted July 27, 2013 I only have the fan, not the coupling, plus I'm miles from you. If its any use in the future, let me know. you'll probably be fine running without the fan if you take it easy, although when most folks say that, its not as warm as it is now. When my last viscous failed, I used the cab heater when the engine got hot in traffic. I was very warm, but it worked! Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 27, 2013 Share Posted July 27, 2013 As long as you're moving you should be fine, as long as your cooling system is set up correctly then even in this warm weather you shouldn't have a problem. I'd just go on holiday and get one on Monday wherever I ended up. Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted July 27, 2013 Author Share Posted July 27, 2013 Got stuck in a tailback on Runcorn bridge and have an led on the dash to show when fan kicks in...well it didnt and temp went up to roughly 105C!Had my little dog in the back so didnt want to use the heater.... Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 27, 2013 Share Posted July 27, 2013 I'm a bit too far in central Lancashire - which way are you travelling ? Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted July 27, 2013 Author Share Posted July 27, 2013 Up to St helens then to Dumfries! Where are you? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 27, 2013 Share Posted July 27, 2013 Near Preston .... It's a hot day too. Between Preston and blackpool to be precise. You'd be welcome to it but I'd need to double check its ok and after 5pm I need to be in to look after my baby girl (I.e no baby sitter). Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted July 27, 2013 Author Share Posted July 27, 2013 Anderzander, have PM'd you... Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 27, 2013 Share Posted July 27, 2013 Failing that there's a Land Rover parts place in Dumfries. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 27, 2013 Share Posted July 27, 2013 I have one that's been in storage at my parents - I don't know much about viscous fans but the spring on the front looks to have been displaced a bit ? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 27, 2013 Share Posted July 27, 2013 It's from a D1 200tdi engine. Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted July 27, 2013 Author Share Posted July 27, 2013 That looks fine to me (until I'm corrected by someone who knows about these things! Lol)Could yo possibly measure the inside of the thread plz and I will measure mine now.... Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 27, 2013 Share Posted July 27, 2013 Approx 23mm inside - a bit less with the threads. Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted July 27, 2013 Author Share Posted July 27, 2013 The inside of the threaded hole should be roughly 22mm... Quote Link to comment Share on other sites More sharing options...
weasel_110 Posted July 27, 2013 Author Share Posted July 27, 2013 Sounds about right Quote Link to comment Share on other sites More sharing options...
Anderzander Posted July 27, 2013 Share Posted July 27, 2013 I've just cleaned it up a bit and the spring now looks fine - one of the centre coils was bent a little so Ive just pushed it back and the spring is sitting nicely now. The fan came with a turner built 200tdi that is for my series 1 - so surplus to requirements. Message me if you can use it - sorry I can't deliver. Quote Link to comment Share on other sites More sharing options...
