csimoes Posted August 15, 2013 Share Posted August 15, 2013 hi after some reading about tuning with MS i have a few questions that maybeyou can help me out. my RR 3.9 runs on LPG 99.9% of the time, only use gas to start and warm up till 45º thenit switchs to LPG. all the AFR tables i've seen are based on stroich of gas 14.7 but if LPG is 15.5shouldn't there be a table based on LPG 15.5?? if gas AFR is 12.5(power) - 14.7(effyciency) - 16.1 (economy) (more or less)a simple translation to LPG (if that's possible..) is 13.3 (power) - 15.5 - 17.1 (+-) if using the gas AFR with LPG, won't it allways be richer than it should? or i should just forget about this because LPG is less efficient than gas and thus running richwill compensate for it? cheers Carlos Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 16, 2013 Share Posted August 16, 2013 Won't that only matter if you have a wideband lambda? If you use a normal lambda sensor, it'll just see the result of the combustion, and tune for that. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted August 16, 2013 Share Posted August 16, 2013 From what I have read lambda is lambda whatever fuel you use, AFR is just a numerical conversion of that lambda value to give you something more meaningful to work with. You can therefore just tune using petrol afrs as if you were running on petrol. This saves reconfiguring anything or any confusion with fuel ratios Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 16, 2013 Share Posted August 16, 2013 Yup as above, it will tune to the correct mix of whatever fuel you run, assuming it's not too wildly out. Quote Link to comment Share on other sites More sharing options...
csimoes Posted August 16, 2013 Author Share Posted August 16, 2013 Ok less work then Thanks Quote Link to comment Share on other sites More sharing options...
