300 TDi vacuum pump outlet snapped
disco_al
There isn't much material to tap near the outlet but with care you might be able to fit a 1/2" bsp fitting.
Be careful and think of the potential headlines ..... LR owner mows down bus queue after bodged repair...
I would ask around here for one that's been swapped due to leaking oil, drill out the rivets and screw the 'new' end cap on to the good body.
There again they are so cheap I'd probably just replace
