disco_al Posted August 17, 2013 Share Posted August 17, 2013 Help! The outlet on my vac pump has snapped off, can it be repaired or replaced? Quote Link to comment Share on other sites More sharing options...
western Posted August 17, 2013 Share Posted August 17, 2013 depending on where the break is, it might be possible to get it welded back on , the parts list doesn't give any parts just a complete vac pump http://lrcat.com/#31/4/53200 Quote Link to comment Share on other sites More sharing options...
disco_al Posted August 17, 2013 Author Share Posted August 17, 2013 right at the point where it joins the body was thinking of drilling the remains out and maybe finding a threaded adaptor of some sort to put in there (after tapping the hole of course). something like an air line hose tail Quote Link to comment Share on other sites More sharing options...
western Posted August 17, 2013 Share Posted August 17, 2013 might work, if the remaining alloy is thick enough to accept a thread. Quote Link to comment Share on other sites More sharing options...
disco_al Posted August 17, 2013 Author Share Posted August 17, 2013 it's right at the housing of the vac pump, i'll try and get a pic next time i'm up there fiddling Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted August 17, 2013 Share Posted August 17, 2013 There isn't much material to tap near the outlet but with care you might be able to fit a 1/2" bsp fitting. Be careful and think of the potential headlines ..... LR owner mows down bus queue after bodged repair... I would ask around here for one that's been swapped due to leaking oil, drill out the rivets and screw the 'new' end cap on to the good body. There again they are so cheap I'd probably just replace Quote Link to comment Share on other sites More sharing options...
western Posted August 17, 2013 Share Posted August 17, 2013 we'r talking 300tdi vacuum pump here not 200tdi, I think the broken bit is the pipe connection on the side, not the on the top cover, isn't there one connection only. there is on my 200tdi vac pump. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted August 17, 2013 Share Posted August 17, 2013 Yes but there isn't much material once the pipe outlet is gone, what I meant was try to get a s/h leaky unit and swap the good end cap and gasket over to the old none broken unit. Or just buy new :-) Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 17, 2013 Share Posted August 17, 2013 Looking at a few pictures on ebay the spigot seems to be screwed in anyway .... so maybe it's just a case of unscrewing the remains of the broken one and replacing it? Certainly cheaper than 60 quid.... Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted August 17, 2013 Share Posted August 17, 2013 I've a couple here and the pipe fitting is part of the casting but different manufacturer maybe use a screw in fitting. Not sure why they would add to the cost by doing so. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 17, 2013 Share Posted August 17, 2013 Fair enough Paul, trust me to have only clicked on the pictures with the screw in ones. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted August 17, 2013 Share Posted August 17, 2013 The screw in ones might be better made overall than the cheapo ones here taken off 'cos they leak :-) Quote Link to comment Share on other sites More sharing options...
