6 pot Posted September 20, 2013 Share Posted September 20, 2013 Good evening I am half way through fitting a 2.8 TGV into my defender however I need it to be 24 volt. The glow plugs starter motor ETC are no problem I used wolf parts. The alternator has the vacuum pump built into the back of it. Can I fit a 24 volt regulator in place of the 12 volt one? Is it that easy? If not where can I get a 24 volt alternator that I can fit my vacuum pump on to? Thanks for your time Cheers Rob Quote Link to comment Share on other sites More sharing options...
Team Idris Posted September 21, 2013 Share Posted September 21, 2013 Give it double the field coil voltage and get double the output voltage? Maybe? I'd ask at re-conditioners, because the same internal parts might do both voltages/units? Or at least have common pump and body. A new one looks a bit pricey, but I guess there is quite a lot to it. And you probably move up from domestic to commercial grade or something Quote Link to comment Share on other sites More sharing options...
pete3000 Posted September 21, 2013 Share Posted September 21, 2013 worth a go on a 24v regulator if you can get the right model i.e a127 at a good price. Or get a small lorry alternator and adapt. Pete Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 21, 2013 Share Posted September 21, 2013 The regulators aren't expensive, worth a try: http://www.ebay.co.uk/itm/A127-24V-REGULATOR-FIT-FIAT-MARELLI-LUCAS-ALTERNATOR-135231-/180954108231 I'm not saying that is the right one, but gives you an idea. Simple to fit too. Quote Link to comment Share on other sites More sharing options...
