Wes Posted November 30, 2013 Share Posted November 30, 2013 Hi all. Ihave a 2002 Disco 2 with just a radio cassette player. Ive been looking for a cd autochanger to fit undwr the seat, The wiring is all there but all the changers ive found all have the wrong connections/plugs. I would be quite happy with a Radio / Single CD player as long as I can retain the steering wheel controls. Any advice would be appreciated. Thanks Wes Quote Link to comment Share on other sites More sharing options...
teabag Posted November 30, 2013 Share Posted November 30, 2013 Has your head unit the facility to control a multi CD player, it depends on the make and model of head unit. There's nothing to stop you fitting an aftermarket head unit, just check the units spec to see if it will interface with the steering wheel controls, if it dose then you will also require the additional patch lead to interface the two. Quote Link to comment Share on other sites More sharing options...
Wes Posted December 1, 2013 Author Share Posted December 1, 2013 Hi. I am assuming so as the leads are in place under the seat and the head unit and column controls have the mode swich function. However will do a bit more checking. Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
teabag Posted December 1, 2013 Share Posted December 1, 2013 Hi. I am assuming so as the leads are in place under the seat and the head unit and column controls have the mode swich function. However will do a bit more checking. Thanks for the reply. Easy to check press the MODE button until CD is shown in the display or look in the user handbook for your unit. Quote Link to comment Share on other sites More sharing options...
slomofo Posted December 7, 2013 Share Posted December 7, 2013 The OEM Multichanger in my '02 Disco is an Alpine, Model XQE100240 - a few on eBay for not much dosh. Might help you find a plug n play option? Quote Link to comment Share on other sites More sharing options...
Mutz Posted December 7, 2013 Share Posted December 7, 2013 I went through the same dilemma as you, cd player or multi changer for my 90; in the end went for the Bluetooth/cd/ipod/aux/usb unit and very glad I did. More tunes available and clearer than cd, well the 800watt amps help lol. Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 7, 2013 Share Posted December 7, 2013 Either the stock changer, or a BMW unit should do. There's serial communication over the IBus between the head unit and the CD changer. I've got the pinouts described here: http://www.rangerovers.net/forum/7-range-rover-mark-ii-p38/46331-project-replacing-cd-changer-raspberry-pi.html Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted December 8, 2013 Share Posted December 8, 2013 Nice work on the ibus pi interfacing! Quote Link to comment Share on other sites More sharing options...
elbekko Posted December 8, 2013 Share Posted December 8, 2013 Thanks, really need to continue with that project, getting sick of listening to the radio Quote Link to comment Share on other sites More sharing options...
