Rangie46 Posted January 12, 2014 Share Posted January 12, 2014 Currently rebuilding my gems 4.0 that's going to get megasquirt, but I also have the complete intake and plenum from my other 3.9 hot wire as well, so what top end would be best to use? The 4.0 gems intake looks better IMHO but what is best for use with ms Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 12, 2014 Share Posted January 12, 2014 I found it easier with a 3.9 plenum, I think the 4.0 one has a different idle valve setup which isn't so easy to utilise. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 12, 2014 Share Posted January 12, 2014 ^^^What he says 3.9 Pros Can easily add PWM Control TPS has wires to join Cons None 4.0 Pros Has 4.0 on it not 3.9 erm ..................... Cons TPS needs special plug to connect to PWM more complex Not as good on air flow as squarer 3.9 reputed to be more flow friendly Quote Link to comment Share on other sites More sharing options...
Rangie46 Posted January 12, 2014 Author Share Posted January 12, 2014 Thanks guys can started cleaning all the 3.9 bits next week ready to get cracking on wit the rebuild Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 13, 2014 Share Posted January 13, 2014 Pretty sure I used the 4.0 fuel rail though, and trumpet base, and switched to 4.0-style breathers. Fuel rail was in some small way better/tidying. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 13, 2014 Share Posted January 13, 2014 4.0 has a much nicer waterproof TPS connector that's standard Durite etc., same as later defender tail lights if memory serves. The 3.5/3.9 ones are nasty and the wires always break/fray going into the TPS. The 3.9 Idle valve hole is easier to utilise for PWM valve, but that's not insurmountable with the 4.0 I reckon. I was running 3.5/3.9 mongrel but am now on a full 4.0/4.6 setup and it's fine and dandy. Quote Link to comment Share on other sites More sharing options...
Rangie46 Posted January 14, 2014 Author Share Posted January 14, 2014 4.0 has a much nicer waterproof TPS connector that's standard Durite etc., same as later defender tail lights if memory serves. The 3.5/3.9 ones are nasty and the wires always break/fray going into the TPS. The 3.9 Idle valve hole is easier to utilise for PWM valve, but that's not insurmountable with the 4.0 I reckon. I was running 3.5/3.9 mongrel but am now on a full 4.0/4.6 setup and it's fine and dandy. Hmmmm fridge are you using idle control on the 4.0/4.6 setup ? Looks easy enough to graft the valve from the 3.9 to the 4.0 when comparing the two to each other Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 14, 2014 Share Posted January 14, 2014 He will when he fits the new lauched kit I gave him - FRIDGE ............... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 14, 2014 Share Posted January 14, 2014 Hmmmm fridge are you using idle control on the 4.0/4.6 setup ? Looks easy enough to graft the valve from the 3.9 to the 4.0 when comparing the two to each other As Nige says, I don't have idle control currently, I will do when I get round to fitting it which is item #273 on the to-do list Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 14, 2014 Share Posted January 14, 2014 Moving up then Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 14, 2014 Share Posted January 14, 2014 Moving up then That depends, there's several lists... And one of the items on the to-do list is "build a garage to do it all in" Quote Link to comment Share on other sites More sharing options...
Rangie46 Posted January 14, 2014 Author Share Posted January 14, 2014 That depends, there's several lists... And one of the items on the to-do list is "build a garage to do it all in" He he my garage looks like a bombs hit it, been tripping up over all sorts but if I was to clean the garage I don't think I'll ever get my engine built:-) Quote Link to comment Share on other sites More sharing options...
