SHY 7G Posted January 13, 2014 Share Posted January 13, 2014 Hi all I've just fitted an uprated lift kit, and I wondered if I could do away with the old self levelling unit on the vehicle (top mounting and cylinder unit only)? just added photo for clarity thanks Rich Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 13, 2014 Share Posted January 13, 2014 With most lift kits they become an irrelevant part of the suspension system, trying to level the car back down to the original ride height all the time. I would take it off if I were you Quote Link to comment Share on other sites More sharing options...
western Posted January 13, 2014 Share Posted January 13, 2014 ditched the Boge strut unit on my 110CSW years ago, when my OME springs & dampers were fitted, the strut was dead & non working. Quote Link to comment Share on other sites More sharing options...
task Posted January 14, 2014 Share Posted January 14, 2014 The CSK went the other direction (down) but I ditched the self leveller at the same time. Quote Link to comment Share on other sites More sharing options...
SHY 7G Posted January 15, 2014 Author Share Posted January 15, 2014 thank all, its coming off and going in my scrap bin to be weighed in at a later date. Quote Link to comment Share on other sites More sharing options...
reggie Posted January 18, 2014 Share Posted January 18, 2014 I haven't removed mine as I haven't touched the A-frame yet, is it much of a job to remove? I have some super pro bushes to fit at some point. Quote Link to comment Share on other sites More sharing options...
western Posted January 18, 2014 Share Posted January 18, 2014 at the bottom ball joint ease back the cover you'll see a thin nut, undo this [used a punch/hammer to undo mine] Top joint undo the 4 bolts of it's bracket that secure the bracket to the chassis, the bottom joint cup can stay as it part of the axle A frame ball joint. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 18, 2014 Share Posted January 18, 2014 Oh and it's quite a lump to drop on your foot, so don't do that Quote Link to comment Share on other sites More sharing options...
Biohazard Posted January 20, 2014 Share Posted January 20, 2014 at the bottom ball joint ease back the cover you'll see a thin nut, undo this [used a punch/hammer to undo mine] Top joint undo the 4 bolts of it's bracket that secure the bracket to the chassis, the bottom joint cup can stay as it part of the axle A frame ball joint. The top has a similar arrangement and mine undid by spinning the whole unit after removing the bottom one. The 4 bolts on the bracket will likely be seized. Quote Link to comment Share on other sites More sharing options...
western Posted January 20, 2014 Share Posted January 20, 2014 if top bracket bolts won't undo, cut the heads or nuts off & drift the shanks out. Quote Link to comment Share on other sites More sharing options...
