NickHodgson Posted October 18, 2006 Share Posted October 18, 2006 I have a 300tdi Defender with Power Steering. My brother in law has been using it and now when I get it back the steering no longer self-centers. I have now replaced and reshimmed the king pin bearings and still no luck. The power steering seems to work fine though. Any ideas what to check next? Quote Link to comment Share on other sites More sharing options...
HoSS Posted October 18, 2006 Share Posted October 18, 2006 Bent rods? Quote Link to comment Share on other sites More sharing options...
Diff Posted October 18, 2006 Share Posted October 18, 2006 I have a 300tdi Defender with Power Steering. My brother in law has been using it and now when I get it back the steering no longer self-centers. I have now replaced and reshimmed the king pin bearings and still no luck. The power steering seems to work fine though. Any ideas what to check next? Check for bent track rod (behind axle) this will cause tracking to be toe out and will make the vehicle wander easily and will affect the self centering. Also check for stiff steering column universal joints between bulkhead and steering box. Regards, Diff Quote Link to comment Share on other sites More sharing options...
NickHodgson Posted October 18, 2006 Author Share Posted October 18, 2006 ok will try those. Thanks Nick Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 18, 2006 Share Posted October 18, 2006 Check for bent track rod (behind axle) this will cause tracking to be toe out and will make the vehicle wander easily and will affect the self centering.Regards, Diff It should be toe out anyway. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted October 18, 2006 Share Posted October 18, 2006 It should be toe out anyway. too much resitance in the steering damper Quote Link to comment Share on other sites More sharing options...
