Dumbsey Posted April 28, 2014 Share Posted April 28, 2014 Hi everyone. My rear lower shock mount snapped off today. I have a 90 with a rear axle from a 200Tdi Discovery. Wanted some advice on where to buy new set of rear mounts (and shocks by the looks of it). Also do i have to remove the axle to fix this of can i manage to do it while axle is still attached? Thanks as always Rhys Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 28, 2014 Share Posted April 28, 2014 YRM Metal solutions for the mount plate and yes you do need a pair of new shocks by the look of it. I think it can be done with the axle on the vehicle, if you have access to a pit or lift it makes it much easier, if not then left and support the vehicle to there's no weight on the springs giving you maximum room between body and axle. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted April 28, 2014 Share Posted April 28, 2014 My main concern is that the radius arm brackets are in danger of the same failure? Quote Link to comment Share on other sites More sharing options...
JeffR Posted April 28, 2014 Share Posted April 28, 2014 Having had a radius arm bracket go on a Disco axle and put me backwards thro a hedge - buy both sets of brackets and be safe. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 28, 2014 Share Posted April 28, 2014 Having had a radius arm bracket go on a Disco axle and put me backwards thro a hedge - buy both sets of brackets and be safe. Both sides of the axles too please Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted April 28, 2014 Share Posted April 28, 2014 I've done this. I took the axle off to do it and found the spring seats where very rusty too, so worth checking those too I'm afraid! Steve Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 28, 2014 Share Posted April 28, 2014 Spare axle? Quote Link to comment Share on other sites More sharing options...
Dumbsey Posted April 28, 2014 Author Share Posted April 28, 2014 Cheers guys! I have not got a spare axle laying around (would be easier) i was going to replace both shock mounts neway, but will deffo look at the radius arms brackets too.Does YRM Metal do them also? Rhys Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 29, 2014 Share Posted April 29, 2014 Believe so Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted April 29, 2014 Share Posted April 29, 2014 YRM do pretty much any repair section, that's where I got all of mine from! Steve Quote Link to comment Share on other sites More sharing options...
Dumbsey Posted April 29, 2014 Author Share Posted April 29, 2014 cheers, looks like good quality stuff and good prices too! Another question, that i know is gonna open a big can of worms is shocks. ATM there are Pro comp ES9000 on front and back. Do i need the same make front and back or is it ok aslong as they are both the same lift (2") how do the Pro comps measure up?any other recommendations? Dont really want to break the bank as all this is unplanned Rhys Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted April 30, 2014 Share Posted April 30, 2014 Surely it would be easier to fit a known good newer axle, that's what I did on mine, so I knew what I had..... Quote Link to comment Share on other sites More sharing options...
ejparrott Posted April 30, 2014 Share Posted April 30, 2014 I've got mixed shocks on The 109, same on each axle, but different each end. Quote Link to comment Share on other sites More sharing options...
Dumbsey Posted April 30, 2014 Author Share Posted April 30, 2014 I dont have a spare axle Disco-ron. Wish i did but i do not. Cheers ejpattot! Quote Link to comment Share on other sites More sharing options...
