Anglo-Frenchman Posted July 27, 2014 Share Posted July 27, 2014 Sorry - noticed I previously posted this on the wrong forum. I've done a bit of research on the archive on this topic and it seems from the sudden whining coming from the fuel tank, that I need to replace the fuel pump in my Disco II. It was replaced about 18 months-2years ago but it appears from what I've read that they are quite prone to failure. My query is regarding where to source a new one from. I live in New Zealand where most suppliers load an extra 300% onto any LR parts from the UK as I found out when I needed some fuel pipes a while ago. I've seen various Discovery II pumps on UK Ebay anywhere between 70-299UKP but wanted to know if anyone can recommend a decent supplier of good quality pump that isn't going require a re-mortgage and who can send out here promptly. Thanks Quote Link to comment Share on other sites More sharing options...
bear Posted July 27, 2014 Share Posted July 27, 2014 Does the vehicle run ok? I'm just wondering if it may be another fault such as air in the system. I'm sure others can give a few pointers. Griff Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted July 27, 2014 Author Share Posted July 27, 2014 Hi Griff, So far it's running Ok, just whining although I've noticed that the whining seems to stop after a kilometer or so. It makes me nervous because I recall that when the pump failed last time, it literally just gave out without warning leaving me stranded at the side of the road. Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted July 28, 2014 Share Posted July 28, 2014 Check your PM box. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted July 28, 2014 Share Posted July 28, 2014 Is it a TD5? If so then get the injector copper oil-seals checked. When they leak they let combustion-gases into the fuel system which rapidly upbuggers the fuel-pump. Whining is a symptom - it's the fuel-system trying to purge the gases from the system. 1 Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted August 12, 2014 Author Share Posted August 12, 2014 Check your PM box. Hi Rangy35 - sorry for the belated reply. Check your inbox! Quote Link to comment Share on other sites More sharing options...
squaddiefox Posted August 13, 2014 Share Posted August 13, 2014 The £60-70 ones work, the all makes have a two year warranty. OEM you will be paying £200 plus. Check one way valves on filter housing pipes and all connections are in good condition before anything else. Just had major problems with one. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted August 13, 2014 Author Share Posted August 13, 2014 Thanks for the info. I'll check this out. Are the one way valves somethnig that can be cleaned or is it a case of replace? I replaced the pump last weekend and initally seemed better but I note that there is still a bit of whining when the pump is primed and starting is still less than enthusiastic when cold. Quote Link to comment Share on other sites More sharing options...
squaddiefox Posted August 13, 2014 Share Posted August 13, 2014 Just seen your sig, you aren't RAF reg? Bain of my life! You can get a new one or people bypass it. If you are still dragging air in try clamping the return pipe. And see if that makes any difference. Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted August 13, 2014 Author Share Posted August 13, 2014 Thanks for the advice Squaddiefox. Been out of the Regt for about 10 years now but once a Rockape always a Rockape! Quote Link to comment Share on other sites More sharing options...
squaddiefox Posted August 13, 2014 Share Posted August 13, 2014 Nearly got me killed in the desert. Twice. Any joy getting it going right? Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted August 14, 2014 Author Share Posted August 14, 2014 Ha ha. Good times. Might have been me - I was in SW Iraq 2003. The Disco is still not 100% but i have been advised to change the fuel filter and micro filter so I'll do that and then see how she goes. Quote Link to comment Share on other sites More sharing options...
