jamesdeval Posted October 26, 2006 Share Posted October 26, 2006 does anyone know wether you can purchase the top brackets for the radiator for the defender conversion i know that a different exhaust is needed and this can be brought. i have never welded before and wondered wehter there available to buy. thanks Quote Link to comment Share on other sites More sharing options...
LR90 Posted October 26, 2006 Share Posted October 26, 2006 Got my rad top brackets from the dealer. Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2006 Share Posted October 26, 2006 you can keep the orignal brackets & folding bonnet stay if you want, it'll be a few less parts to buy & more pennies for something else. but if you want the genuine 200 rad brackets they are RH ---- ESR283 LH ---- ESR282 as supplied in my 200TDi retro-fit kit or from 5/3/1992 RH --- ESR68 LH --- ESR69 plus 2 x rubber washer ------------ NRC5544 or use the existing ones 4 x bolt ------------------------- SH106207L 4 x plain steel washer --------- WC106047 Quote Link to comment Share on other sites More sharing options...
jamesdeval Posted October 27, 2006 Author Share Posted October 27, 2006 thanks for that where about do you get the "retro fit kit" from? Quote Link to comment Share on other sites More sharing options...
western Posted October 29, 2006 Share Posted October 29, 2006 thanks for that where about do you get the "retro fit kit" from? you can't anymore as the 200Tdi is out of production, LR did these kits complete with engine & ancillaries to enable older vehicles to have the 200Tdi, put one in my 110 around mid '94. the part numbers above will get you the correct brackets. Quote Link to comment Share on other sites More sharing options...
davidlandy Posted October 29, 2006 Share Posted October 29, 2006 I just chopped the pins from the top of the old defender rad and welded them onto the new disco one. u then use the standard defender brackets. Quote Link to comment Share on other sites More sharing options...
jamesdeval Posted October 29, 2006 Author Share Posted October 29, 2006 ok thanks for that i will keep you posted on ghow it goes Quote Link to comment Share on other sites More sharing options...
JST Posted October 30, 2006 Share Posted October 30, 2006 i did the same as David advised above, as per the article in the tech archive, certainly the easiest way to do it. Quote Link to comment Share on other sites More sharing options...
