Series one axle casing will range rover diffs fit,
Redbolt
Yes if it is the later build, but maybe not if it is the weird diffs (long nose? for 1948/9) Even then only the props change (as far as I know)
It was a common fix to save an overdrive back in the day.......... The diff comes from the rover car originally like the gearbox, and the axle case looks pretty much the same. They stretched it a bit width ways for S2/3 and a bit more for rangy. The only change you see is the metric diff, which has two more long studs. But still the same flange pattern. Other than that it all pops in each other :)
It's nice when they don't change stuff ^_^
  • 4 weeks later...
