gonewestnz Posted October 11, 2014 Share Posted October 11, 2014 Hi all, just got my ARB pump up hose out to check and discovered it has a small split (5mm or so long) in the Orange pipe. Is there a way to repair this? Is it possible just to buy a replacement hose ? Is there a better quality hose available with the arb fitting? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted October 11, 2014 Share Posted October 11, 2014 Quite likely just standard fittings. What does it look like? Quote Link to comment Share on other sites More sharing options...
gonewestnz Posted October 11, 2014 Author Share Posted October 11, 2014 The hose has a push in connection at the compressor but knowing arb it is their own fitment as it is smaller than the standard compressor fittings I may have a go at removing the fittings and sourcing a hose to fit them on as don't reall want to pay for a full replacement pump up kit if I don't have to. Quote Link to comment Share on other sites More sharing options...
Boydie Posted October 11, 2014 Share Posted October 11, 2014 No, it's a standard fitting - although there are several types on the market, take it along to any reputable pneumatic hose supplier and you can get a replacement hose and fitting(s) or simply have the split section cut out and a new fitting installed. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 12, 2014 Share Posted October 12, 2014 IIRC those fittings are described by ARB as American. Mo Quote Link to comment Share on other sites More sharing options...
Lewis Posted October 12, 2014 Share Posted October 12, 2014 Cant you just cut the split section out and use a straight joiner? Quote Link to comment Share on other sites More sharing options...
gonewestnz Posted October 12, 2014 Author Share Posted October 12, 2014 May try cutting and re joining, any recommendations for a suitable hose joiner? Found a reasonably cheep replacement but would be good to fix this one as a spare. Quote Link to comment Share on other sites More sharing options...
Lewis Posted October 12, 2014 Share Posted October 12, 2014 Something like this http://pages.ebay.com/link/?nav=item.view&alt=web&id=390596173281 You'll need to know the size of your pipe [the above link is not necessarily my recommendation just the first eBay search hit] Quote Link to comment Share on other sites More sharing options...
gonewestnz Posted October 12, 2014 Author Share Posted October 12, 2014 Thanks 10mm o/d 7mm I/d is the size and I ordered off the link above, was thinking the internal ones would be stronger but would also restrict air flow a little, I'll see how these hold up in the field have ordered a couple just in case more splits appear Quote Link to comment Share on other sites More sharing options...
