Loose Stainless Rivnut
need4speed
I have discovered a loose stainless rivnut on my bulkhead. Is it possible to just nip it up using the nut/bolt method or will i need to try and remove it somehow?
Thought id ask opinions here before trying it and totally buggering it up..
You can try to pinch it up a bit more but in my experience its worse than pot luck.
Best bet is to tack the head to the bulkhead with the TIG
If you have to fetch it out the best way is to drill the head off, or maybe use a powerfile/10mm belt sander if there's access. Either way if its into a hollow section then you are gonna gain a new rattle
