need4speed Posted January 28, 2015 Share Posted January 28, 2015 Does anyone do kits with brass nuts? The only kits i can find are from volksbolts but they are stainless studs and nuts, which might prove troublesome.. Quote Link to comment Share on other sites More sharing options...
JeffR Posted January 28, 2015 Share Posted January 28, 2015 From memory I looked at this a year or two back and found the only way was to buy the stainless kit then source brass nuts from elsewhere (I think it was Vehicle wiring products, but it could also have been Namrick) Quote Link to comment Share on other sites More sharing options...
chris200100 Posted January 28, 2015 Share Posted January 28, 2015 Rimmer bros do a stud kit with brass nuts. Quote Link to comment Share on other sites More sharing options...
chris200100 Posted January 28, 2015 Share Posted January 28, 2015 Just checked and its £42 part no EF1001 Quote Link to comment Share on other sites More sharing options...
need4speed Posted January 28, 2015 Author Share Posted January 28, 2015 Thanks guys Quote Link to comment Share on other sites More sharing options...
robertspark Posted January 28, 2015 Share Posted January 28, 2015 what thread are the exhaust manifold bolts? Can you not just get some corresponding studs and brass nuts? (I did buy the rimmer bros kit when I did my tubular exhaust on the rv8, now with the LS, think I'll just get the M8 studs and brass nuts). Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 28, 2015 Share Posted January 28, 2015 5/16" UNF, assuming you mean the downpipes. Quote Link to comment Share on other sites More sharing options...
stuck Posted January 28, 2015 Share Posted January 28, 2015 Phil, I used the Rimmer Bro's kit when I changed my exhaust, decent bit of kit The brass nuts have around twice the depth of a standard nut so you will be less likely to strip them. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 29, 2015 Share Posted January 29, 2015 Last set I bought were from Minispares or something like that, fine thread on the nut side too. Quote Link to comment Share on other sites More sharing options...
robertspark Posted January 29, 2015 Share Posted January 29, 2015 http://www.ebay.co.uk/itm/5-16-UNF-BRASS-EXHAUST-NUTS-WASHERS-FITS-JAGUAR-E-TYPE-XK-MK2-XJ6-MK10-/110776526515?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19cacba6b3 http://www.ebay.co.uk/itm/Ford-Exhaust-Manifold-Studs-5-16-UNC-Brass-Nuts-Washers-/141106648796?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20da9c96dc http://www.ebay.co.uk/itm/5-16-x-1-11-16-UNC-UNF-Manifold-Studs-With-Brass-Nut-MGB-Exhaust-Flange-/371001625213?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item56616b8a7d enough options to order a few sets of whatever you need from the above options for 5/16" UNF, no? Or these if you wanted long nuts? http://www.ebay.co.uk/itm/Brass-UNC-UNF-5-16-Manifold-Exhaust-Extra-Long-Nuts-MG-MGB-MIDGET-And-More-/371181189384?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item566c1f7908 Quote Link to comment Share on other sites More sharing options...
