3.9v8 guages vdo etc. temp and oil pressure.
gti-90
I believe VDO made the original ones for Land Rover, hence the good match.
I added VDO temp gauge (needed to replace temp sender as well), VDO fuel gauge (I think the fuel tank level gauge is iffy - but it goes from full on the gauge(full in the tank) to empty on the gauge (tank 50% full), so better than the original gauge it replaced) and VDO rev counter. Rev counter fed from W terminal on alternator and switchable for V8.
I got a bit carried away and also added VDO voltmeter, VDO oil pressure gauge, existing vacuum gauge and an AFR gauge in the mud dash.
Thanks for the replys. I will be going for vdo it seems they have a good following.
I'm assuming that oil pressure is worth having? If so 5 bar or 10?
I might change the fuel as that's iffy too.
Anybody know the temp sender required for a non serp 3.9?
Thanks
