bishbosh Posted February 22, 2015 Share Posted February 22, 2015 Ok so my black and decker powerfile has died and I am thinking of replacing it with an air powered version. Any recommendations out there? Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted February 22, 2015 Share Posted February 22, 2015 My Makita electric file gets more use than my air powered - it seems to be working well and is comfortable to use for long periods. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 22, 2015 Share Posted February 22, 2015 Interested to hear the recommendations as well... my powerfile is still going strong. but I've thought about an air one now I have a decent compressor. Quote Link to comment Share on other sites More sharing options...
zardos Posted February 23, 2015 Share Posted February 23, 2015 I looked at a powerfile but I went with a cheap from the bay Neilsen branded one and used it lots with no problems.The main reason for going air was the are much smaller than the powerfile so easier to get in to places that a sanding flat wheel on a small grinder cannot get, especially as you can adjust the angle of the finger. One downside is that it can get quite colder to hold with prolonged use. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted February 23, 2015 Share Posted February 23, 2015 All my air tools chill with use and I do find it uncomfortable... Yeah yeah use your gloves but it's a downside, my cheapo Lidl DA sander doesn't though. The belt on the air file is a bit short so it wears a bit too quickly but agree access is better. Rips the stud of recalcitrant front shocks in just a few seconds though Quote Link to comment Share on other sites More sharing options...
zardos Posted February 23, 2015 Share Posted February 23, 2015 If you want a longer / larger belt then you can get a 20mm x 520mm version instead of the 10mm x 330mm (black and decker is 13mm x 455mm) (probably still has better access than the power file) Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted February 23, 2015 Share Posted February 23, 2015 The Makita is 9 x 535 but a 13mm arm is an option, anyway op wants air so it's just for info. http://www.axminster.co.uk/makita-9032-filing-sander Quote Link to comment Share on other sites More sharing options...
