muddy4x4xfar Posted February 28, 2015 Share Posted February 28, 2015 hi all whats the largest tyre size i can have on a standard height discovery 2? Quote Link to comment Share on other sites More sharing options...
Boydie Posted February 28, 2015 Share Posted February 28, 2015 What engine ?? Auto or Manual ?? Look up Ashcroft's site and they have a gearing table for you to enter all your cars specs and you can see the result of altering te standard tyre profile Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 2, 2015 Share Posted March 2, 2015 255/70R16 or 245/75R16 - you can fit 265/75R16 but they'll rub at the front unless you do a bit of modification. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted March 2, 2015 Share Posted March 2, 2015 hi all whats the largest tyre size i can have on a standard height discovery 2?Firstly what do you want large tyres for? Not saying don't do it, but it's good to know the why. Are you wanting width, height or both? For example, tall narrow tyres are likely easier to fit than shorter wide ones. What rims are you wanting to use, as not all tyre sizes are available in all rim sizes. You'll also need the correct width rim for the tyre. But importantly, offset will dramatically affect if a wheel fits or not. Lastly, you say standard height, does this mean standard suspension? Is it air or coil at the back? Gearing - less of an issue tbh. Are you happy to trim the wheel arches? If so, then you'll be able to fit a lot bigger. Quote Link to comment Share on other sites More sharing options...
