davidlandy Posted November 11, 2006 Share Posted November 11, 2006 fed up with water coming into the heater vent on the wing after a little deep wading - what options are there to stop as much water as poss from getting in there other than blocking it up? ...and i dont like those plastic scoop things! Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2006 Share Posted November 11, 2006 Probably very little to stop any water getting in there, except for don't cross deep water. Quote Link to comment Share on other sites More sharing options...
reedx Posted November 11, 2006 Share Posted November 11, 2006 fed up with water coming into the heater vent on the wing after a little deep wading - what options are there to stop as much water as poss from getting in there other than blocking it up?...and i dont like those plastic scoop things! How about a military snow cover - 3/4 way down this page https://secure.pablanchard.co.uk/spares.asp Colin Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 11, 2006 Share Posted November 11, 2006 Take the rubber drain thing out of the bottom of the plastic trunking under the grille and throw it away. They get bunged up and don't let the water drain. You will be left with a hole the size of a 2p underneath - now it will drain properly. Worked a treat for me and it was free HTH Mo Quote Link to comment Share on other sites More sharing options...
nige90 Posted November 12, 2006 Share Posted November 12, 2006 What about ducting the heater intake through a snorkel type affair ???? Nige Quote Link to comment Share on other sites More sharing options...
Andy Posted November 12, 2006 Share Posted November 12, 2006 wasnt there a milly snorkel system that came from the heater vent on the wing? im sure a mate got one from sodders a year or two ago. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 12, 2006 Share Posted November 12, 2006 wasnt there a milly snorkel system that came from the heater vent on the wing? im sure a mate got one from sodders a year or two ago. That's for the marines winterised rovers.... the heater ducting is extended down to the front "nose" of wing (you'll see a series 3 type heater intake grill just near the sidelight/indicator lights), and the engine intake goes up through the original heater ducting (if that makes sense!) I've got one of the military "snow ducts" (as per the blanchards site). works a treat, i can go through water a la camel trophy style, and no water gets in the heater at all, although it does reduce the amount of air coming through the heater a little bit. Quote Link to comment Share on other sites More sharing options...
