tonyker Posted May 17, 2015 Share Posted May 17, 2015 hi all i have a 90 v8 with 200tdi axels, wondering if td5 axel would fit on the rear cheers Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 17, 2015 Share Posted May 17, 2015 Yep, Disco 1 axles will fit aswell but the 300 tdi has a 3 bolt flange on the different so you'd have to swap them as well. Quote Link to comment Share on other sites More sharing options...
Litch Posted May 17, 2015 Share Posted May 17, 2015 Any 90 rear axle will fit, I have just fitted a 2011 TDCi 90 rear axle to my 1986 90 and it was a straight swop. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 17, 2015 Share Posted May 17, 2015 Erm, don't they have a different diff in them, meaning you need a longer propshaft? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 17, 2015 Share Posted May 17, 2015 Erm, don't they have a different diff in them, meaning you need a longer propshaft? Only on the 110, the late TD5's onwards use the P38 diff and strengthened rover axle, not the Salisbury Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 17, 2015 Share Posted May 17, 2015 Ah ok, thanks Quote Link to comment Share on other sites More sharing options...
tonyker Posted May 17, 2015 Author Share Posted May 17, 2015 thanks all have ordered one thanks for the help Quote Link to comment Share on other sites More sharing options...
tonyker Posted May 17, 2015 Author Share Posted May 17, 2015 one thing forgot to ask what do i do about the abs? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 17, 2015 Share Posted May 17, 2015 If you don't have ABS on your truck, just ignore it No need to plug anything on the rear axle, front is a slightly different matter Quote Link to comment Share on other sites More sharing options...
miketomcat Posted May 18, 2015 Share Posted May 18, 2015 Td5 disco rear axle may not fit as it has a watts linkage not an A frame. Mike Quote Link to comment Share on other sites More sharing options...
tonyker Posted May 23, 2015 Author Share Posted May 23, 2015 hi all got the axel yesterday and was in the process of taking off the diff for have a locker installed and ran in to a slight question. the axel was sold to me as a td5 off a 2004/2005 90 axel. but looking how the diff guard goes on I'm a bit confused the holes for this are at the side behind one another rather then beside each other underneath. can anybody shed any light on this. cheers Quote Link to comment Share on other sites More sharing options...
tonyker Posted May 23, 2015 Author Share Posted May 23, 2015 ok I'm now pretty sure its a 110 rear axel can you fit this to a 90 without any problems? cheers Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 23, 2015 Share Posted May 23, 2015 Sounds like you've been sold a 110 axle - they have a different diff with a short nose. I think a standard long nose diff will fit in the axle casing so you can get your locker built into a long nose diff and fit that Quote Link to comment Share on other sites More sharing options...
tonyker Posted May 23, 2015 Author Share Posted May 23, 2015 thats for the reply. would it work if i fitted a 110 prop shaft? Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 23, 2015 Share Posted May 23, 2015 No. A 110 rear prop will be significantly longer than the gap you want it to fit into Quote Link to comment Share on other sites More sharing options...
