Souster Posted May 19, 2015 Share Posted May 19, 2015 In need of a vacuum pump for my 300tdi. Which brands would you advise? Or is it luck of the draw? Britpart Bearmach (£10 Dearer than BP) OEM Wabco (£30 dearer than bearmach) Anyone got any experiences with either brand? And why it was good or not? Many thanks Quote Link to comment Share on other sites More sharing options...
Tanuki Posted May 19, 2015 Share Posted May 19, 2015 What do you use your Landy for? If it's your daily-driver/the vehicle that you depend on to earn your living with, go for the genuine Wabco [of course if it's a vehicle you use for work you will be offsetting the full cost of parts&labour against your business taxes anyway so it's not a cost to you to go for the full-price option]. What is the likely cost to you of the cheap replacement part failing prematurely and so meaning you're possibly not earning for a day? If it's just a second/third car or a weekend plaything doing a few thousand miles a year, you might be happy to go for the cheaper option and accept the risk of being stranded at the side of the M6 on a wet sunday in November. Similarly, consider the time/cost of fitting the part (or paying to have someone else fit it). It 'costs' the same amount to fit a cheap crappy part as it does to fit a top-quality one. The cheap crappy part may even take longer to fit if you need to 'fettle' it before its mounting-holes will line up (yes, I've dealt with Britpart-supplied gasket-sets with incorrectly positioned holes). Do you want to do the job again in six months and waste your invested time from the first time round? Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted May 19, 2015 Share Posted May 19, 2015 Wabco. If it's only £40 more expensive imagine how much extra it would cost if you had to do it again. Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 20, 2015 Share Posted May 20, 2015 To be honest they're all a bit pants and cheaply made especially the OEM one... the aluminium rivets they use for the top assembly stretch and then you start getting the oil leaks... Quote Link to comment Share on other sites More sharing options...
rick Posted May 23, 2015 Share Posted May 23, 2015 To be honest they're all a bit pants and cheaply made especially the OEM one... the aluminium rivets they use for the top assembly stretch and then you start getting the oil leaks... Yep, agree, and IMO Wabco are pretty poor, for an OE part, they aren't up to snuff. Had a problem with one Bearmach pump, but was replaced promptly (faulty batch, the welsch plug fell out !) but the last Bearmach one has been fine. Quote Link to comment Share on other sites More sharing options...
