SvBeek Posted June 2, 2015 Share Posted June 2, 2015 I want to install a 200tdi snorkel (left side of the car) on my RHD 110. Originally it was a 2.25 petrol, it doesnt have the side air intake on the wing. So i have to cut out the hole. Can someone take some measurements for me how far it should be from the bulkhead and top of the panel? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted June 2, 2015 Share Posted June 2, 2015 You could go through the top of the wing instead. Gets it out the way..... However if you have no joy I'll try and do it Sunday, next time I visit the 110 Quote Link to comment Share on other sites More sharing options...
SvBeek Posted June 2, 2015 Author Share Posted June 2, 2015 Don't really like that since the heater and washer bottle are in the way. Would have the hose go all the way forward on the wing. And have all the bits lying around to make the side entry, just need to cut the hole. Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2015 Share Posted June 2, 2015 Can do some details when I get home later Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 2, 2015 Share Posted June 2, 2015 Here is ours: The snorkel actually goes down outside the heater and the hose goes under it between wheel arches and bulkhead. Mine is home made but a copy of iirc mantec one for series and early 90/110. The side mount snorkel requires the plastic under wing duct fitted at the factory which I believe is no longer available. Mike Quote Link to comment Share on other sites More sharing options...
western Posted June 2, 2015 Share Posted June 2, 2015 Can do some details when I get home later Photo's as promised if you need more just shout Quote Link to comment Share on other sites More sharing options...
SvBeek Posted June 3, 2015 Author Share Posted June 3, 2015 Thanks Western! Quote Link to comment Share on other sites More sharing options...
western Posted June 3, 2015 Share Posted June 3, 2015 Those are for the intake recess, if you need to see the actual hole I can pop the grille off Quote Link to comment Share on other sites More sharing options...
SvBeek Posted June 3, 2015 Author Share Posted June 3, 2015 Nah its ok like this. The bottom of the snorkel has a similar shape compared to the intake. Maybe its a few mm smaller, but that shouldnt make the difference. Quote Link to comment Share on other sites More sharing options...
