Mikeing Posted September 26, 2015 Share Posted September 26, 2015 Hi chaps The front prop on my auto td5 is knackered. I wanted to buy complete unit rather than fitting new ujs. Why is the front prop shaft for the automatic so expensive- almost £400. Can I fit a manual front prop shaft ?! £180ish What's the difference between the two? Cheers Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 27, 2015 Share Posted September 27, 2015 I think the auto one is skinnier to miss the gearbox (from memory - could be wrong!) I don't know how it would work for motorway speeds as road speeds here are lower, but we always used to fit 300Tdi Defender front props to the Td5 Discoverys, which are much cheaper, no double cardan joint but never noted any vibration problems. It may be different at higher speeds. Quote Link to comment Share on other sites More sharing options...
teabag Posted September 27, 2015 Share Posted September 27, 2015 Good question, but with pricing an item it would be better to ask the seller than a user. Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 1, 2015 Share Posted October 1, 2015 Get part numbers and google image both, also dimensions are worth googling too, there is usually a good reason. I know a front prop for a 3.9 D1 is expensive due to it being a skinny solid bar as opposed a tubular effort. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 1, 2015 Share Posted October 1, 2015 The skinny one was fitted to RRC to clear the catalytic converters.... Guess D1 had same issue. Quote Link to comment Share on other sites More sharing options...
hangover Posted October 5, 2015 Share Posted October 5, 2015 RRC with TF727 used a solid shaft also. Quote Link to comment Share on other sites More sharing options...
