Yolandi Posted February 1, 2016 Share Posted February 1, 2016 New one for me, my 110 has started vibratiting strongly (and noisely) when going downhill over 55mph, but only if the engine speed is matching the wheels or accelerating, as soon as you let off the gas its instantly smooth, and ideas? Quote Link to comment Share on other sites More sharing options...
rich broom Posted February 1, 2016 Share Posted February 1, 2016 Prop uj Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 But i have just had a new front prop put on? And i didnt do this before it was fitted Quote Link to comment Share on other sites More sharing options...
rich broom Posted February 1, 2016 Share Posted February 1, 2016 Are the bolts right and correct length prop Quote Link to comment Share on other sites More sharing options...
rich broom Posted February 1, 2016 Share Posted February 1, 2016 Tight I meant Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 All bolts are new and as tight as i can get them bar one, one of the previous bolts was used again for whever reason, its slightly shorter and a bit rubbish looking Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 Oh forgot to say, the 3 new bolts are stainless and the 1 other is steel, would that be enough to throw the balance? Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 1, 2016 Share Posted February 1, 2016 Has the prop been separated into its two pieces? If so, it needs to be assembled with the two yokes slightly out of direct alignment. There's a small difference of two spline positions (which is 22.5 degrees / a sixteenth of a full turn) to allow for the angles of the flanges on the transfer box front take off and the front diff. I don't know if your symptoms could be caused by this but it's worth checking anyway if the prop's been off. Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 I can confirm that the two yokes are slightly out of alignment Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 1, 2016 Share Posted February 1, 2016 It won't cause your problem, but is wouldn't be using stainless bolts in a prop. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted February 1, 2016 Share Posted February 1, 2016 Do you have a suspension lift? Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 How come not stainless? My local garage did this when my uj collapsed, they have had a good record in the past but kinda bodged this one Quote Link to comment Share on other sites More sharing options...
Aragorn Posted February 1, 2016 Share Posted February 1, 2016 Stainless bolts arent as strong as normal HT steel bolts. I would expect a propshaft to be attached with 10.9 grade bolts. Most stainless steel doesnt even match 8.8 grade. Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 Aragorn - ah right Dailysleaze - no i dont, suspension is standard as far as im aware Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 1, 2016 Share Posted February 1, 2016 Indeed. My understanding is they don't stretch as much, more brittle, so could fail. A prop is under some fairly high stress, especially on a 110. Your noise could also be a pinion bearing, Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 Mk, the garage told me that stainless has higher shearing force than steel amd thats what you want in a twisty thing not so much a pulling. but if it was a bearing wouldnt the vibration continue when i let off the accelerator Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 1, 2016 Share Posted February 1, 2016 Even if they are, you do not want bolts with a lower elasticity, because they can deform, and then they come loose. What your mechanic is telling you is not true. Bearing noise can act exactly that way. Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 Ah ok, ill swap them out for steel when i change the pinion seal which is currently leaking, how do i check the bearing? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 1, 2016 Share Posted February 1, 2016 Just check for play side to side and in/out. Any perceptible movement can be noisy. The fact the seal is leaking means it is more than possible the bearing is toast. Quote Link to comment Share on other sites More sharing options...
Yolandi Posted February 1, 2016 Author Share Posted February 1, 2016 Ok thanks Quote Link to comment Share on other sites More sharing options...
